Jimgeriatric Posted September 21, 2016 Share Posted September 21, 2016 Hi all I am wondering is it possible to change above by some means it seems way ott to take subframe off with all it,s problems of realigning after!!. Regards and best wishes to all Jim Quote Link to comment Share on other sites More sharing options...
Boilermansab Posted September 22, 2016 Share Posted September 22, 2016 I'd like to know the answer to this as well as mine is a bit creaky at the front when going over speed bumps. had a look and there doesn't seem much room for a spanner to undo the clamps Quote Link to comment Share on other sites More sharing options...
Jimgeriatric Posted September 22, 2016 Author Share Posted September 22, 2016 Many thanks for your reply you are right very tight I thought maybe remove one bolt then slacken other then bend up and slide old bush forward and reverse procedure but don't really want to start it if it's a no go as my name I plays too old to play under cars in the cold if it's a none runner.!! Quote Link to comment Share on other sites More sharing options...
Boilermansab Posted September 26, 2016 Share Posted September 26, 2016 Maybe post in the fiesta forum..as it should be the same 1 Quote Link to comment Share on other sites More sharing options...
