WillKinsella Posted September 21, 2016 Share Posted September 21, 2016 So my full set of new lights from CEUK came today, and decided why not make a start to fitting them. So started with the dipped beam and main beam along with side lights, no bother at all. All completed. Started raining so wrapped things up. Next thing I went to do was the number plate lights thinking it would take 5mins top, however.. I can't get the thing out! I manage to loosen it, but can't pull it out completely! A guide or some sort of help for this moron would be appreciated! Cheers Quote Link to comment Share on other sites More sharing options...
Tom-B64 Posted September 22, 2016 Share Posted September 22, 2016 You've got to be brave! Did you order the bulbs or the light units? Quote Link to comment Share on other sites More sharing options...
Guest Posted September 22, 2016 Share Posted September 22, 2016 Hi mate, there should be a little metal clip you have to press down to remove each unit, you will need to use a flat head screw driver. Quote Link to comment Share on other sites More sharing options...
Guest Posted September 22, 2016 Share Posted September 22, 2016 watch this! Quote Link to comment Share on other sites More sharing options...
dave_k Posted September 22, 2016 Share Posted September 22, 2016 Allen key around 3 or 4mm is fine I found (decent length one as the clips can be a bit tight and you need to use a little force). Also a fine cloth to protect the paintwork if you can (should be ok without if your careful). Quote Link to comment Share on other sites More sharing options...
WillKinsella Posted September 22, 2016 Author Share Posted September 22, 2016 Ahhh, I see how it's done now! I was trying with a larger flathead that wouldn't fit in the small gap thing. Looks like an Allan key works a treat. Cheers lads. Quote Link to comment Share on other sites More sharing options...
WillKinsella Posted September 22, 2016 Author Share Posted September 22, 2016 Job done, took about 2mins once I knew where the clip was, looks epic! 1 Quote Link to comment Share on other sites More sharing options...
L22EEW Posted September 25, 2016 Share Posted September 25, 2016 Small flat head screwdriver would have also done the trick ;) 1 Quote Link to comment Share on other sites More sharing options...
WillKinsella Posted September 25, 2016 Author Share Posted September 25, 2016 50 minutes ago, L22EEW said: Small flat head screwdriver would have also done the trick ;) That's what I used;) may I ask what lights you have for your headlights? They seem extremely bright! I fitted mine from CEUK but they don't seem half that bright or blue Quote Link to comment Share on other sites More sharing options...
L22EEW Posted October 9, 2016 Share Posted October 9, 2016 On 9/25/2016 at 6:01 PM, WillKinsella said: That's what I used;) may I ask what lights you have for your headlights? They seem extremely bright! I fitted mine from CEUK but they don't seem half that bright or blue Sorry bud, only just seen this. Got mine from AliExpress --> HID's Bought in Feb 2015 and still going strong. Bought a spare set just in case ;) Although no longer available by that seller - they're widely available by other sellers. Quote Link to comment Share on other sites More sharing options...
