Adamsku Posted September 24, 2016 Share Posted September 24, 2016 Hi Guys, I am a newbie who is currently waiting on delivery of a new 16 plate fiesta zetec s/st line black edition... the waiting is just painful I will be looking at installing an active sub to the ford dab sync headunit but cant find any info on how to install one? Isit something that can be done quite easily? Or takes abit of time? I know im suppose to have a rca converter but have never installed a sub on a non-aftermarket headunit before, so not sure how to wire the converter up. Cheers for any info that can be provided. Adam Quote Link to comment Share on other sites More sharing options...
Paramanic Posted September 24, 2016 Share Posted September 24, 2016 check out my guide i made for fitting a underseat subwoofer :) Quote Link to comment Share on other sites More sharing options...
Adamsku Posted September 25, 2016 Author Share Posted September 25, 2016 9 hours ago, Paramanic said: check out my guide i made for fitting a underseat subwoofer :) Thanks for that dude The piggybacking to the fuse box solution looks good because i wont have to bother with trying to route the power to the battery and the remote to the headunit. Do i have to cut the original headunit wires when using the rca converter? Or is there another way without doing that. Quote Link to comment Share on other sites More sharing options...
Paramanic Posted September 25, 2016 Share Posted September 25, 2016 yes you do but if got alot of power for your sub in boot or underseat? if in boot get power from battery mate i did this :) Quote Link to comment Share on other sites More sharing options...
Dan P Posted September 25, 2016 Share Posted September 25, 2016 I took a slightly different approach in installing my sub.. check it out in my build thread here. Quote Link to comment Share on other sites More sharing options...
Adamsku Posted September 26, 2016 Author Share Posted September 26, 2016 When it comes to the rca converter cables, can i not just use scotch locks to attach the amp cabling to the headunit cabling so i dont need to cut any of the wires? Quote Link to comment Share on other sites More sharing options...
Paramanic Posted September 28, 2016 Share Posted September 28, 2016 scotch locks are good in thought but in reality are crap they cut into wire anyway plus after time they loosen mate better to cut into wires the way i shown on my guide as ye can plug them back together anyway haha 1 Quote Link to comment Share on other sites More sharing options...
tazzman600 Posted September 28, 2016 Share Posted September 28, 2016 Scotch locks NO NO NO. Paramanic is sooooo right. 1 Quote Link to comment Share on other sites More sharing options...
Waynedance Posted June 5, 2021 Share Posted June 5, 2021 I know this is an old thread, did anyone find away of the sub staying on when you switch off the engine until you open the drivers door like the radio does. Quote Link to comment Share on other sites More sharing options...
