Why is the Focus st tdci oil dipstick useless (2.0 TDCI)
james_60
 Share
Hello Everyone,
I have owned my Focus st tdci for a year next month,
I have noticed that everytime i go to check the engine oil level it is impossible to get an accurate reading.
I do the following
1. remove dipstick Wipe, Replace,
2. Remove dipstick try and see where the oil line is and fail because the oil goes over and above the max line.
3. i try a 2nd time and see the same result as 2.
Is anyone else having this issue with the 1997cc Duratoq TDCI engine (Code DW10) fitted to most Fords since its introduction in 1999
Jamie
Link to comment
Never had an issue with the DW10 in Peugeots, owned several of them...Ford probably ruined it.  The 2.0 petrol in the Fiesta is impossible to get a reading from lol, have to dip 2 or 3 times and take an average... :laugh:
  • Like 1
Link to comment
The ford garage said its the correct part number, even tried a different one,
alas
Jamie
p.s i have not added oil in the time that i have owned it, (nov) and i have covered 8500 miles
Link to comment
On 10/7/2016 at 8:03 PM, james_60 said:
Hello Everyone,
I do the following
2.Rotate dipstick 90 degrees clockwise using handgrip and remove quickly..
3.Repeat 2-3 times
try that.
and are you checking oil level when the engine is hot or cold ?   it can make a difference......
  • Like 1
Link to comment
I've had this problem in the past, not just with Fords. I find that removing the dipstick, wiping and waiting a minute or several before replacing/withdrawing it to gauge the level allows the oil in the tube to settle for a more accurate reading. The more you stick the dipstick in and take it out the more oil accumulates in the tube, banjaxing the reading
FWIW I let the dipstick drip into the bonnet catch before wiping. Waste not... :smile:
  • Like 1
Link to comment
On Friday, October 07, 2016 at 8:03 PM, james_60 said:
Hello Everyone,
I do the following
Jamie
Is it a sporty short throw dip stick fitted from factory?
Like a short shift gear box but oil stick version 😉
Link to comment
Unlike Vauxhalls where the Dipstick is applied after purchase, accessible from the cabin.
  • Like 3
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
