huey45 Posted October 19, 2016 Share Posted October 19, 2016 Hi Guys Im thinking of fitting a Wifi reverse camera to help with reversing my touring caravan the camera will be fitted obviously to reverse of van, with power for transmitter and camera taken from caravan reverse lights, the car will have the camera receiver fitted inside the car with power taken there the only thing im not sure about is the My Ford 8" touch screen is there a RCA type plug for a camera input ? and how do I remove the head unit to gain access to RCA socket the guide I found was for a 2012 model can anybody shed some light if this is doable, and how to gain access to camera input ? Regards huey45/Keith Quote Link to comment Share on other sites More sharing options...
DJ_Andy_M Posted October 19, 2016 Share Posted October 19, 2016 UK models do not have an RCA input as far as I am aware. Mine certainly doesn't, and there are no options in the software for it. Quote Link to comment Share on other sites More sharing options...
goldtail77 Posted October 19, 2016 Share Posted October 19, 2016 8 hours ago, DJ_Andy_M said: UK models do not have an RCA input as far as I am aware. Mine certainly doesn't, and there are no options in the software for it. In the 2 weeks I had my Mondeo Mk5 with the 8" screen. It had RCA in the centre console. My TitX Focus doesn't. Though I'm suspicious that the actual unit might. If you have an endoscope type camera have a nosey about :) Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted October 19, 2016 Share Posted October 19, 2016 You can buy a RCA module that retrofits into the wiring loom at the back of the radio. Sent from my SM-G930F Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted October 19, 2016 Share Posted October 19, 2016 http://www.car-interface.com/vendita/en/interfaces-a-v-video-ford/655-ford-sync-2-myford-touch-video-in-motion-interface-with-aux-video-inputs.html Sent from my SM-G930F Quote Link to comment Share on other sites More sharing options...
huey45 Posted October 20, 2016 Author Share Posted October 20, 2016 Thanks Guys for all the info supplied, I know you can have the Tit with a optional reverse camera surely that must plug into the standard display, to give reverse vision, I just dont have the camera on mine, but display must be the same ?, and the other question, how do you remove the display to see ?? Quote Link to comment Share on other sites More sharing options...
Bannko Posted October 20, 2016 Share Posted October 20, 2016 Hallo Huey45, this is how you can get the screen out: Quote Link to comment Share on other sites More sharing options...
kpg Posted October 20, 2016 Share Posted October 20, 2016 When I did the reverse camera mod on my car, the screen had to be connected to by a FAKRA connector. Had to buy an adaptor for the camera to fit said connection on the back of the screen. Quote Link to comment Share on other sites More sharing options...
kpg Posted October 20, 2016 Share Posted October 20, 2016 Something similar to this (white): Quote Link to comment Share on other sites More sharing options...
Bannko Posted October 20, 2016 Share Posted October 20, 2016 30 minutes ago, kpg said: When I did the reverse camera mod on my car, the screen had to be connected to by a FAKRA connector. Had to buy an adaptor for the camera to fit said connection on the back of the screen. Yeah...the revers camera for the Facelift is connected directly to SYNC II. You can connect there any aftermarket camera you want. But you need additionaly to activate it in your BCM using Focccus or similar software. Here is the wiring scheme for the reverse camera in Focus MK3.5: Rear View camera Sync Gen 2 - Focus mk3.5.pdf 1 Quote Link to comment Share on other sites More sharing options...
SteveGSXR600K1 Posted October 21, 2016 Share Posted October 21, 2016 19 hours ago, Bannko said: Hallo Huey45, this is how you can get the screen out: Hi Bannko, On a different note, I've got to fit some Ford Nolden DRL lights to my Focus MK3 and was wondering how to safely get the triangle sections out. Do you have any step-by-step pictures, simlilar to above, on how to remove them without breaking any tabs, etc? Quote Link to comment Share on other sites More sharing options...
Bannko Posted October 21, 2016 Share Posted October 21, 2016 10 minutes ago, SteveGSXR600K1 said: Hi Bannko, On a different note, I've got to fit some Ford Nolden DRL lights to my Focus MK3 and was wondering how to safely get the triangle sections out. Do you have any step-by-step pictures, simlilar to above, on how to remove them without breaking any tabs, etc? Regarding to the DRL installation. You have to put the whole front bumper down and loosen the triangles from inside. https://www.youtube.com/watch?v=Yi8Um1OP1xY And please see this thread: Quote Link to comment Share on other sites More sharing options...
huey45 Posted October 21, 2016 Author Share Posted October 21, 2016 Hi I fitted the triangular DRL's that I bought from a source in China, but as post above I did not take the whole bumper down on my 2012 Mk3 Focus 1.6 Titanium its a bit fiddly but I got my car front end up on ramps so I could get right under the triangle, and released the plastic clips one by one, whilst my friend outside the car pulled the triangles towards him, so they would not spring back in, so we did a joint effort, right corner yes, left corner yes, if you chose to take out on a warm day the plastic clips are not brittle, if you do it on a cold day you have a chance of breakages, what also helps a plastic type implement to put into front gaps to prise out, when guy underneath is releasing the clips one by one...I did both of mine in about 20mins and never broke into a sweat, have fun... Quote Link to comment Share on other sites More sharing options...
