Focus mk3 Bluetooth replacement
paddyb
Hi all - done a few searches but nothing 100% answering my question, so grateful for any help.
I have a late 2011 UK Focus mk3 Titanium (Sony DAB radio). For a few months I noticed poor sound quality with the bluetooth audio, and one day it stopped connecting to the phone completely. Did the usual diagnostics of trying different phones, disconnecting battery etc. - no luck.
I took it to a main dealer and was quoted several hundred to have the bluetooth module replaced. This seemed high, and I was unimpressed by their service so decided to look elsewhere.
Replacement modules are available on eBay for part AM5T-14D212-EB for £25 or so.
So, questions:
Is this the right part for the vehicle?
Is it a DIY job? I would honestly rate my car maintenance skills as beginner level, although I'm fairly capable with electronics in general.
If not, could a local garage do it, or would it need to be a main dealer for programming codes etc?
Cheers for any help.
Have you tried doing a firmware update on the radio? This might resolve it.
Do you have Sync 1 or just a normal Sony radio?
If you P/M me your cars VIN I'll have a check on Microcat to see what module is compatible.
Sent from my SM-G930F
A 2011 Focus MK3 has the old bluetooth/Voicecontrol system. Depending on production date the car should have a module with part number 8M5T-19C112-Ax or CS7T-14D212-Ax (the x is the revision of the module and basically can be any letter). Both modules are technically interchangeable. Howver personally I would prefer the newer, more advanced CS7T-14D212-Ax module.
A module with part number AM5T-14D212-EB is a SYNC 1.0 module. SYC modules are not compatible with the Bluetooth/Voicecontrol system.
