Focus Tyre monitoring system
JamboChris
 Share
I have a July 2014 Focus 1L ecoboost, had it for 6 months.
I've just put my Winter steel wheels/tyres on and now I'm getting a "tyre monitoring system malfunction warning" The pressures are correct, the malfunction warning has been reset by resetting the pressure on the dashboard but it comes back after a few miles. It is not a tyre pressure warning but a system malfunction warning.
Looking at my 18" Summer wheels/tyres, the valves look like normal rubber valves not chunky so I thought the pressure monitoring system is based on the ABS and not a sensor in the wheel.
Ford Etis says, " Tyre Pressure Sensors - 433 MH"
Does anyone know for definite if my Summer wheels have sensors in them? If thats the case then I'll need to get them fitted to my Winter wheels.
Thanks,
Chris
Link to comment
2014 should be sensors in each wheel, and they have rubbrr valves. recheck your summer valves and feel or look for a single ridge around rubber valve , if ridge then deffinatly sensors attatched to them
  • Like 1
Link to comment
The TPMS is malfunctioning because the monitoring valves are in the other set of wheels which ain't on the car providing that you changed your wheels
Sent from my OnePlus 3 using Tapatalk
  • Like 1
Link to comment
1 hour ago, JamboChris said:
Thanks,
Chris
Yes, its a standard feature now because they are a requirement for all new cars to have.
http://www.techeurope.co.uk/tech/news/view/35/European-legislation-on-TPMS-imminent
  • Like 1
Link to comment
2 hours ago, iantt said:
should be, not exactly difficult to fit, any competent tyre fitting bay can fit them
Thanks again,
hopefully my final question. Do the new new tyre monitors need coding to the car or will it just work?
Link to comment
they can be coded but they are supposed to be also self learning. basicaly fit tge wheels, ign on, reset tps, ign off, leave for 20 mins, then take to a drive. something like that. this info was from@jw1982. i have fitted single sensors , i just reset and drove for 5 mins . worked fine.
  • Like 2
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
