What caused this? Paint issue
TomsFocus
 Share
As title really, I have a very specific patch of bad paint on the Focus.  It didn't look so bad in summer when it was clean but looks awful now that dirt is sticking in the gaps.  I know it can't be fixed without a respray but I'm intrigued to know what caused it to try and avoid it anywhere else!!  I'd owned it 2 years before this suddenly developed, hasn't had any paint in that time but might've done before.
Any ideas!?
Link to comment
not sure about the first answer, does not look like scratches to me. Looks like it is like the paint has shrunk. Do you agree?  It is hard to tell in the picture
My 1982 Suzuki motorbike has a patch like that on one side of the petrol tank. 99% sure it is original paint. I had the bike store for 19 yrs. I don't recall it being like that before I stored it but noticed it when I got it out of the depths of my garage after 19 years. No idea what caused it.
Link to comment
Hmm, interesting! :unsure:
I don't believe it's bush scratches either, I've got plenty of those as well but they are far less deep and all 'flow' along the side, rather than the erratic pattern here.  I also wondered if I'd damaged it when cleaning but again that would either be straight lines or swirls I think!
I guess you could say the paint had shrunk, I'm not really sure how to describe it other than looking like the crazing that you get in antique china items.
Link to comment
Could be an area that has been repainted during it's life. but it has a spider web pattern of paint cracking. it may be possible to have it detailed to at least lessen the visibility of it and depending on how bad it is depends on whether paint correction could cure it and bring it back to normal finish.
GIYF http://www.drbeasleys.com/blog/2011/07/13/solving-dry-car-paint/
Link to comment
you can get that from putting hot water on a frozen car ie washing it in winter the paint effectively shrinks and cracks it looks cracked to me not sure if an issue when the car was painted could cause it years later
Link to comment
Would that work the other way as well, ie cold water on a hot car?  It happened back in the summer at some point.
Link to comment
Tbh I won't be spending any more on the car now so it'll have to stay like that, I just want to make sure it doesn't happen again really! :unsure:
Link to comment
Yes, cold enough water will cause a sudden drop in temperature and the paint to contract slightly. Could be enough to crack it, especially as it becomes brittle with age.
Most things in this world do not like sudden temp changes in either direction.
  • Like 2
Link to comment
as above if the body was hot enough yes it'll crack.....bear in mind you could cook an egg on the cars paint in summer .. in summer use warm water in winter use cold water never hot on cold or cold on hot
Link to comment
Have you seen the Top Gear Middle East special?  They couldn't cook an egg on the back of an MX5 in the desert! :laugh:
I'll keep that in mind though, can't really use warm water to pre-rinse the car with the car from the hose but I'll just have to make sure it's cool before washing in future.
Link to comment
I have seen this before exactly the same . I expect that your  car wing has been repainted as some stage this problem appears some time after the paint job has been done. Funnily enough it was also on a Ford (Ford Escort MK2) the first time I saw this sort of thing. Looks like a re spray to me to fix it. In my opinion I would be very surprised if it was anything else.
  • Like 1
Link to comment
Looks very similar to what happens on fibreglass top coats over time. I reckon it is previous repair with some filler involved.
Heat would expand the metal but filler would not.
  • Like 1
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
