ST 170 Alloys
williamweb
 Share
Hi everyone,does anyone know if the ST 170 alloys is a straight swap to my MK 1 1800 diesel because I took the alloys to my tyre fitter for the upgrade and said they don't fit ha ha so I've got 4 alloys with brand new tyres in the boot at the moment.
Link to comment
I'm sure it's a strait swap. Why don't u just put the 2 fronta on with ur jack and see if they rub on full lock. If they don't rub then they fit. But loads of people have got st170 wheels on a mk1 Focus so I don't think it will be a problem
Link to comment
The alloy wheel centres won't fit on the hub.I've just had the wheels refurbished my fitter seems to think the new paint on the inside of the centres is so thick that it's too tight to get on.Should I burnish the internal centre down or maybe take it to a machine shop and get it hollowed out to the same as my OEM alloys?
Link to comment
30 minutes ago, williamweb said:
I think I'm going to buy a 80 grit flap wheel and sand the internal centre down and remove the paint.
Yeh I agree just sand it down a bit
  • Like 1
Link to comment
Are the wheels powdercoated? If so the company who powdercoated the wheels is the one to blame. When powdercoating wheels all mating faces and wheel nut holes must be covered using masking tape or plugs to prevent the powdercoating to attach to these surfaces.
ST170 wheels will fit perfectly to any "normal" MK1/MK1.5. The only thing to be aware of is the tyre size. The ST170 has a different tyre size than the "normal" Focus MK1/MK1.5. The ST170 uses 215-45-17 while the "normal" Focus MK1/MK1.5 uses 215-40-17.
Link to comment
Yes the tyres are 215/45/17 the same as on the ST 170 and yes they have powder coated the internal mating surface.I think i'm going to try washing up liquid first,see if that works.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
