Broken spark plug
Hello you lot
in August I had a misfire no engine light
the 2nd plug along from timing belt had broken
i changed all 4 and all was fine until Thursday just gone
cruising along the A2 doing 70 suddenly car started to slow and engine light came on I managed to get off motorway and called RAC he plugged his machine in and code came up saying plug number 2 had a misfire
it was the same plug as before and had snapped in half ????
he replaced all four plugs and all is good again
he also said he has no idea why a plug would break like that and maybe I had been unlucky
Has anybody got a view on this and what might have caused it to break ?
Thanks for reading
unless it was over tightened I can't see a reason why a spark plug would break to be honest it could be it was overtightened they only need to go in hand tight then a quarter turn with a ratchet maybe someone else has another theory
That's exactly what the RAC man said but he didn't think they were too tight ?
I am hoping I've just been unlucky
Define snapped in half? did the metal body snap, leaving the threaded portion in the head or was it the electrode end with damage.
My guess is yo could have a fuelling/cooling problem to that cylinder. The Sparkplug could be getting too hot.
Yes it was a clean break at the base of the ceramic bit
so the plug was in 2 pieces
on the first plug it was the top that had broken leaving the threaded bit and ceramic case
Is number 2 plug difficult to access at all?  Needs to be dropped in rather than placed?  Cross-threaded so there's a slight lateral force on it when tightening?
Tbh I'd be wondering about the coil pack, putting too much voltage through that plug.  Just an idea though as I haven't seen it happen twice in a row either!
Coil pack is a good shout. It might be worth replacing it anyway as a precaution.
If the plug goes a 3rd time you could end up with debris in the cylinder, not a pleasant thought.
Thanks guys
i might just have a look at coil pack
the coil pack couldn't put out enough current or heat to snap a plug to be honest ide change the plug apply a thin smear of copper grease to the thread on the plug and carefully fit ensuring it doesn't tighten if you're changing a coil pack you need to change the leads easy way to spend £100
But be careful with the torx screws, they can be hard to remove. Even my garage could not remove them!
Thanks again guys
The RAC man changed the plugs and put stuff round the threads etc etc
he was very careful putting plugs in and tightening them
he was very good even checked for anything odd before he put plugs in and said there was nothing obvious and it all looked clean and tidy
  • 3 years later...
Sorry to revive an old thread but I have this exact problem changed plugs and coil on cylinder 2 on 58 plate 1.8 zetec and just done it again, did you fix it?
