TomsFocus Posted November 26, 2016 Share Posted November 26, 2016 You still not changed that radio yet?? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted November 26, 2016 Share Posted November 26, 2016 Have a read of this excerpt from the Ford workshop manual- Basically the Dealership should be able to do a DTC scan and pinpoint if it's an actual module failure or simply a communication failure between the modules themselves. Quote Link to comment Share on other sites More sharing options...
Glowrom Posted December 4, 2016 Author Share Posted December 4, 2016 I've change the Radio still the same ***** off now Quote Link to comment Share on other sites More sharing options...
richardbell556 Posted January 4, 2017 Share Posted January 4, 2017 sure Halfords do retro fit kits for your model . bin it and just put a standard din fit radio in and take ford out of the problem . Quote Link to comment Share on other sites More sharing options...
RjH Posted March 11, 2019 Share Posted March 11, 2019 On 11/23/2016 at 9:36 AM, TomsFocus said: In 2 years of no use it could've got damp inside and broken tbh. Bit of a long shot but do you know anyone else with a Mk7 Fiesta that could borrow their radio to test? Also have you definitely pressed the on button? It's the volume knob on them iirc. Hi, I just came on with the same problem after getting a new battery. Turns out I didn't realise there was an on button! Thanks so much for pointing out the obvious 🙂🙂 🙂 1 1 Quote Link to comment Share on other sites More sharing options...
4616 Posted November 23, 2019 Share Posted November 23, 2019 My car is doing exactly the same as this. I picked it up from the dealers, where it had sat with a flat battery for an unknown amount of time. Did you ever get to the root of the issue? 1 Quote Link to comment Share on other sites More sharing options...
4616 Posted November 23, 2019 Share Posted November 23, 2019 My car is doing exactly the same as this. I picked it up from the dealers, where it had sat with a flat battery for an unknown amount of time. Did you ever get to the root of the issue? Quote Link to comment Share on other sites More sharing options...
Ian318 Posted November 24, 2019 Share Posted November 24, 2019 My dads focus had problem with radio , we warmed it up with hairdryer and it turned on was just something i saw on online forums , but think radio had fault , hes not got the car now though. Quote Link to comment Share on other sites More sharing options...
