peanuts Posted December 1, 2009 Share Posted December 1, 2009 just replaced my glowplugs on my 2003 2.0 tdci after persistant problems with fuse blowing ! replaced all four partly to be sure and so i didnt have to take the inlet manifold off again anyway fuse still blowing so looks like i have a deeper problem was wondering if there are any common causes of this that i have to look out for eg timer relay connector blocks etc help ? Quote Link to comment Share on other sites More sharing options...
InstructorPiggy Posted December 1, 2009 Share Posted December 1, 2009 inspect the main wire that runs from/to the glow plugs, easiest to start at the plugs, ensure the wire touches nothing but the plugs, follow it into the loom, often they wear away at one point through the shroud and rubbing against the block/earth. Look carefully, wont take much. Piggy :) (double check the fuse rating too, maybe fitted too low.) Quote Link to comment Share on other sites More sharing options...
peanuts Posted December 2, 2009 Author Share Posted December 2, 2009 Ta mate was thinking along those lines myself was looking more for schematic wiring diagram or something along those lines as there aint one in the haynes for the glow plug circuit any body have or know where i can find something like that ? Would be a real help to trace the fault Quote Link to comment Share on other sites More sharing options...
InstructorPiggy Posted December 2, 2009 Share Posted December 2, 2009 go with the obvious and have a look, its unlikely to be deep in the loom, coz its all protected, but look for it where it goes round a bend on the block or across another pipe etc :) Quote Link to comment Share on other sites More sharing options...
