Aaron Harris Posted December 4, 2016 Share Posted December 4, 2016 Hi has anyone fitted a 12V socket in the boot of a focus MK3? Quote Link to comment Share on other sites More sharing options...
Big stu Posted December 4, 2016 Share Posted December 4, 2016 No but I have tried to use my battery optimiser thru the 12v sockets and they stop working after a few minutes it must shut the sockets down after a short while stopping me optimising my battery ----any ideas [emoji362] Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Aaron Harris Posted December 4, 2016 Author Share Posted December 4, 2016 17 minutes ago, Big stu said: No but I have tried to use my battery optimiser thru the 12v sockets and they stop working after a few minutes it must shut the sockets down after a short while stopping me optimising my battery ----any ideas Sent from my iPad using Tapatalk Have you checked the fuse for the socket? Quote Link to comment Share on other sites More sharing options...
JW1982 Posted December 4, 2016 Share Posted December 4, 2016 Some time ago I installed a 12 Volt socket in the boot of my 2013 Focus MK3 hatchback. I connected the 12 Volt socket to the fuse box in the boot. This fuse box should have at least a few empty positions which can be used to connect additional equipment. My 12 Volt socket is connected exacly the same way as the 12 Volt socket of the Focus MK3 wagon (which has a 12 Volt socket as standard). The 12 Volt socket in the boot has a permanent 12 Volt power supply. All other 12 Voilt sockets in the car have a switched 12 Volt power supply (only 12 Volt if the CANbus system is active). 1 Quote Link to comment Share on other sites More sharing options...
Aaron Harris Posted December 4, 2016 Author Share Posted December 4, 2016 5 minutes ago, JW1982 said: Some time ago I installed a 12 Volt socket in the boot of my 2013 Focus MK3 hatchback. I connected the 12 Volt socket to the fuse box in the boot. This fuse box should have at least a few empty positions which can be used to connect additional equipment. My 12 Volt socket is connected exacly the same way as the 12 Volt socket of the Focus MK3 wagon (which has a 12 Volt socket as standard). The 12 Volt socket in the boot has a permanent 12 Volt power supply. All other 12 Voilt sockets in the car have a switched 12 Volt power supply (only 12 Volt if the CANbus system is active). Great just learnt something new didn't know there was a fuse box in the boot as well. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
JW1982 Posted December 4, 2016 Share Posted December 4, 2016 Most Focus MK3 versions have the fuse box in the boot. Only low spec versions which do not have any options that require the rear fuse box do not have this fuse box. Quote Link to comment Share on other sites More sharing options...
Aaron Harris Posted December 4, 2016 Author Share Posted December 4, 2016 Ok I will have a look in the week. Got a Zetec so hopefully there is a fuse box. Got parking sensors so they might be taken off that fingers crossed my life so much easier. Quote Link to comment Share on other sites More sharing options...
