Replacing rear hubs
Gavin01
 Share
Both my rear bearings are in need of replacement. On the way to changing from drums to discs on the back of my Focus MK2.5, I'm going to replace the rear hubs. I've looked in the haynes manual and if I'm right, the process should be fairly straightforward.
From what I gather, I need to;
* Remove the wheel.
* Remove the drum.
* Remove the ABS sensor.
* Undo the 4 bolts from the rear of the hub mount.
* Remove the hub.
* Install the new hub.
It seems the drum backing plate (and drum shoes etc) are mounted upon the same 4 hub mounting bolts. In theory, if one is careful, one could simply swap out the hubs without needing to touch the brakes?
Does anyone have any experience doing this? And is it as easy as seems?
  • Like 1
Link to comment
It is very straightforward but you may be faced with rounded bolts and also the hub will most likely be seized into the suspension arm.
A set of spiral fluted extractors if the bolts are rounded off and a hammer and some form of bar to whack the hub out from the suspension arm.
  • Like 1
Link to comment
11 hours ago, artscot79 said:
the bolts should be replaced trust me ive had it done reusing the old bolts and the hub worked loose they are stretch bolts
Yea, I've seen new hubs on eBay that come with new bolts so that was my assumption. Funnily, I dont think it mentions that in the Haynes manual. Could be wrong though.
Link to comment
no it doesn't but if you reuse they won't tighten enough the dealer realised they're mistake that's when they said they can stretch and with the hub not sitting right it knackers the new bearing
Link to comment
  • 3 weeks later...
* Remove the wheel.
* Remove the drum.
* Remove the hub.
How did you get on. If you have done it yet?
I hate my drums at the back thinking of changing to discs.
Link to comment
I've just ordered the parts today. Will be attempting them this weekend. I too am thinking of changing to discs. But that will probable be a summer job as I have no experience bleeding brakes or adjusting the handbrake cable.
Link to comment
You don't need to do either, unless they need done already.
  • Like 1
Link to comment
So you can just re-use the existing brake lines with the new calipers?
Link to comment
Why are you changing calipers? replacing pads and discs is simple.
I have rear drums. I am changing to discs in the near future.
Link to comment
ah right, I'm with you now fella
Lol.. so, I'm correct in assuming I would need to change the brake lines and handbrake cable?
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
