Dave1981 Posted December 14, 2016 Share Posted December 14, 2016 Just noticed both front door window seals on my mk2.5 r showing signs of mould and the rubber is starting to break up. I believe the correct name is the exterior cantrails? Could be wrong though. Anyway anyone got any idea how I can remove the mould without resorting to replacing the entire rubber seal but if I have too how much of a job is it to swap them out? 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted December 14, 2016 Share Posted December 14, 2016 1 hour ago, Dave1981 said: Just noticed both front door window seals on my mk2.5 r showing signs of mould and the rubber is starting to break up. I believe the correct name is the exterior cantrails? Could be wrong though. Anyway anyone got any idea how I can remove the mould without resorting to replacing the entire rubber seal but if I have too how much of a job is it to swap them out? Ford only give 12 months warranty on all rubber parts, It's the frost on the window tares the rubber when opened aswell. my guide to fitting puddle lights will help show how to remove the rubber door sill strips, It's also worth cleaning out the drain holes in bottom of the doors with some WD40 while there, anyway here's the guide: Guide to fitting Ford puddle lights Focus 05-12 Click Here Quote Link to comment Share on other sites More sharing options...
Dave1981 Posted December 14, 2016 Author Share Posted December 14, 2016 Cheers dude.. 1 Quote Link to comment Share on other sites More sharing options...
