ajzetecs Posted December 18, 2016 Share Posted December 18, 2016 bit of advice needed before inspect my cat, on acceleration 1st 2nd 3rd gear mainly getting a whistle noise like split pipe, getting worse over week gone, its not the 90deg pipe as that is silicone and been replace because of split on that one which cause a totally different noise more like air blowing through vents. Noticed oil over the end of that pipe close to egr. any ideas asap Quote Link to comment Share on other sites More sharing options...
Dennis the meance Posted December 18, 2016 Share Posted December 18, 2016 Could be the other intercooler hoses follow the 90 degree bend onto metal pipe it's goes into another rubber hose behind drivers side headlight where it connects to intercooler and another rubber hose passenger side of intercooler aswell Quote Link to comment Share on other sites More sharing options...
ajzetecs Posted December 18, 2016 Author Share Posted December 18, 2016 4 hours ago, Dennis the meance said: Could be the other intercooler hoses follow the 90 degree bend onto metal pipe it's goes into another rubber hose behind drivers side headlight where it connects to intercooler and another rubber hose passenger side of intercooler aswell had a good look at hoses top end of engine all seem ok, need to remove paneling underneath to see the intercooler hoses, well if its a split just gona change to silicone so they last longer Quote Link to comment Share on other sites More sharing options...
Tomson Posted December 20, 2016 Share Posted December 20, 2016 On 18/12/2016 at 10:04 AM, ajzetecs said: bit of advice needed before inspect my cat, on acceleration 1st 2nd 3rd gear mainly getting a whistle noise like split pipe, getting worse over week gone, its not the 90deg pipe as that is silicone and been replace because of split on that one which cause a totally different noise more like air blowing through vents. Noticed oil over the end of that pipe close to egr. any ideas asap did you find the cause? Quote Link to comment Share on other sites More sharing options...
ajzetecs Posted December 21, 2016 Author Share Posted December 21, 2016 10 hours ago, Tomson said: did you find the cause? not really mate, havnt had time to check hoses at bottom of car, starting to get a noise like turbo is spinning on de-acceleration Quote Link to comment Share on other sites More sharing options...
