ck238 Posted December 19, 2016 Share Posted December 19, 2016 Hi all, I hope I can get some advice with a problem I am experiencing whilst on holiday in Germany. My Focus Estate (2.0l petrol, ZF automatic) developed an issue on the way to Germany - there is hardly any power transmission in 4th gear. Changing gears works fine, no warning lights / messages, no smells, normal temparature. Driving on the motorway, all is fine in 4th gear (at around 70mph), but as soon as there is the slightest incline the speed drops and I can only rev up the engine, but no power seems to be transmitted. Can change gears manually, and everything seems to be fine in 1st to 3rd. A friend who is a mechanic had a quick look and said there is enough oil, but can't do more as he is not a specialist. No idea how serious this is and if I can make it back to the UK (around 700 miles). Trying to see a specialist for automatic gearboxes tomorrow and the Ford garage if that doesn't help. I am trying to find out whether it is a smallish fix that can be done in Germany whilst I am here, whether I could make it home (possibly taking more time and using 3rd only), or if there is no hope and I need to get a new gearbox (which would be a whole other issue given the age of the car). Any advise would be appreciated, I tried to find the problem online but no luck finding the same problem. Thanks, Chris Quote Link to comment Share on other sites More sharing options...
mjt Posted December 20, 2016 Share Posted December 20, 2016 I have to admit I know very little about auto transmissions other than the basics. I'm assuming from your description (ZF automatic) that it's a classic fluid-flywheel auto box. Ratio selection is done using hydraulically-actuated friction bands or clutches to lock a set of planetary gears. It sounds as if the band or clutch for 4th gear has started slipping. I guess this might be due to a lack of hydraulic pressure or wear of the friction faces. Only an auto transmission specialist will be able to give you a definitive diagnosis. 1 Quote Link to comment Share on other sites More sharing options...
trailertrash Posted December 20, 2016 Share Posted December 20, 2016 Sorry I can't help re the problem but as ZF is a German company it might be worthwhile getting it diagnosed, and possibly fixed, whilst in Germany. Good luck! I love auto cars, usually very reliable but when they go - ouch! ££££s Quote Link to comment Share on other sites More sharing options...
Incontro Posted December 20, 2016 Share Posted December 20, 2016 On 12/19/2016 at 5:27 PM, ck238 said: Hi all, I hope I can get some advice with a problem I am experiencing whilst on holiday in Germany. My Focus Estate (2.0l petrol, ZF automatic) developed an issue on the way to Germany - there is hardly any power transmission in 4th gear. Changing gears works fine, no warning lights / messages, no smells, normal temparature. Driving on the motorway, all is fine in 4th gear (at around 70mph), but as soon as there is the slightest incline the speed drops and I can only rev up the engine, but no power seems to be transmitted. Can change gears manually, and everything seems to be fine in 1st to 3rd. A friend who is a mechanic had a quick look and said there is enough oil, but can't do more as he is not a specialist. No idea how serious this is and if I can make it back to the UK (around 700 miles). Trying to see a specialist for automatic gearboxes tomorrow and the Ford garage if that doesn't help. I am trying to find out whether it is a smallish fix that can be done in Germany whilst I am here, whether I could make it home (possibly taking more time and using 3rd only), or if there is no hope and I need to get a new gearbox (which would be a whole other issue given the age of the car). Any advise would be appreciated, I tried to find the problem online but no luck finding the same problem. Thanks, Chris Hi Chris, Sorry to hear about the problems you've been experiencing, hope you manage to get it sorted soon! Just for reference - your Focus most likely has a Mazda/Ford auto transmission (Ford 4F27E), rather than ZF, assuming yours is a UK market model. It is technically a 3-speed unit, the fourth gear is an over-drive ratio. Rather than pretend to be an auto trans specialist, I'll link below a useful article I found. Page 13 mentions the most common cause of a slipping fourth gear: http://www.atraonline.com/gears/2006/2006-01/2006-01_08.pdf Also, googling issues with this particular unit yields this forum post: http://www.focusfanatics.com/forum/general-technical-chat/307628-no-4th-gear.html Good luck, let us know how you get on! 1 Quote Link to comment Share on other sites More sharing options...
ck238 Posted December 21, 2016 Author Share Posted December 21, 2016 Hi all, thanks all for your help, absolutely fantastic. I went to the specialist (as Ford price for new gearbox is not an option). He test drove it and checked the oil - oil does smell burned and when driving in 3rd the same problem occurs in high speed / revs. He did not think we would make it home as 3rd gear would go as well. He will now re-built which seems to be the best compromise, still quite expensive but around a third Ford would charge for a new one. Hopefully ready in time for travelling back, or a slightly longer holiday. Fingers crossed it will all work out. Thanks again for the support, will let you know when back in the UK :-) Chris 1 Quote Link to comment Share on other sites More sharing options...
trailertrash Posted December 21, 2016 Share Posted December 21, 2016 Best of luck and Happy Solstice! Have a cool Yule too Quote Link to comment Share on other sites More sharing options...
v530anh Posted December 22, 2016 Share Posted December 22, 2016 I also had a very slight oil burning smell in the car when I would rev up the engine. Though I had a sealed gearbox, but I managed to change a litre of the gear oil and the burning oil smell went away. I also noticed that spraying WD40 under the gear cover onto and around the spring improved gear handling. Though your problem sounds more serious. Quote Link to comment Share on other sites More sharing options...
