Ford dealer said rear spring broken
v530anh
 Share
Just now, dezwez said:
makes it a bit easy to do as its the outside one :smile:
Yup, still a messy encounter though! Never fails that I end up head to toe in cv grease :lol:
Link to comment
I'd like a pair of hydraulic ones, hate using the manual ones I've got, usually walk down the local garage to have springs swapped instead lol.  I just don't quite use them enough to justify buying a set yet. :unsure:
Link to comment
9 minutes ago, stef123 said:
Those work well. I use a portable hydraulic unit for doing mobile work. Fitted who knows how many hundred springs with it lol. So many I had to service the hydraulic ram not so long ago.
when my  hydraulic unit pack up i fixed it with a jack see pic
  • Like 3
Link to comment
cant beat a broken coil spring or 2. keeps me in a job. lol
  • Like 1
Link to comment
Redneck style lol
  • Like 1
Link to comment
1 minute ago, stef123 said:
Redneck style lol
works well and saved me £50.00 for a new ram
Link to comment
7 minutes ago, stef123 said:
What failed on it? Why not just repair it.
didn't no you could:sad:
thought the rams were sealed unit
Link to comment
You should be able to, they are just basic hydraulics usually with crap seals lol.
Link to comment
I will give it a go for some reason i keep it
Link to comment
Just now, stef123 said:
Here is a pic of mine, stripped down to clean and rebuild.
Were did you get all the spare parts from:smile:
Link to comment
I stripped it down, measures up the seals and ordered them online from a hydraulic spares place, which I can't remember the name of lol
Link to comment
cheers i will look in to that :smile:
Link to comment
If you want to send me some pictures over I'll help you out with what you need to do/get.
  • Like 1
Link to comment
Thanks i will give you a pm when i find it i have 3 sheds its somewhere in them
  • Like 3
Link to comment
51 minutes ago, stef123 said:
Redneck style lol
Id Have used the cordless drills flipped the car
Link to comment
i did one on a corsa this morning without getting messy. lol
Link to comment
It must be me then, maybe trying to justify myself too much lol
Link to comment
no, i just got lucky today, and the corsa, theres plenty of room on the o/s drive shaft to remove the outer joint without getting in a mess
Link to comment
Very true. Remove the outer joint and burn the rest lol.
Link to comment
just burn the lot, leave it long enough and it will do it itself.
Link to comment
I bought a Halfords Jack today low profile as i was to use  on the pavement. Their axle stands we're min 33cm, so just had to raise the car high enough!
Anyway once the wheel was off, I could clearly see the spring was broken, but it is broken at a very low level there is very little risk of it falling out. Sprayed wd40 and a little autosol around some rust and put the wheel back on.
I have decided to leave it, and the spring seems good  just a little rust at the bottom got the best of it.
I can see it is easy to change the spring, just 2 bolts. But the rust on these nuts!
I don't think the m.o.t guy will find out, unless he takes the wheel off.
  • Like 2
Link to comment
If the spring is broken anywere they will fail your car and if it’s a call back to check
If you have done the work and it fails you will have to have it re mot again full cost to you
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
