Pedmk3 Posted January 8, 2017 Share Posted January 8, 2017 Hi my driver side dipped beam bulb blew the other day so i changed the bulb, i checked the bulb everything worked fine until i started my car then this caused it to blow again so i replaced that bulb checked it and it was fine until i started the car which made it blow again, both have now blown when i started the car. I have tried changing the bulbs with different makers just incase it was due to the bulb. Any ideas? Quote Link to comment Share on other sites More sharing options...
Ryan_Tango Posted January 8, 2017 Share Posted January 8, 2017 Are you being careful when placing the new bulb in? I know on halogens you're not supposed to touch the bulbs glass as it can cause them to blow straight away. 1 Quote Link to comment Share on other sites More sharing options...
Pedmk3 Posted January 9, 2017 Author Share Posted January 9, 2017 Ye i always use gloves and never touch the bulb, they light up until the car is turned on then they blow Quote Link to comment Share on other sites More sharing options...
biff55 Posted January 9, 2017 Share Posted January 9, 2017 if you've got HIDs then probably the ballast. if you've got standard halogen bulbs then possibly damaged lampholder or a short between live & the chassis on the wiring harness to the headllight. we can rule out overvoltage spikes from the alternator as this would blow both headlamps. my moneys on the lampholder. Quote Link to comment Share on other sites More sharing options...
flynnthomas78 Posted January 7, 2020 Share Posted January 7, 2020 This problem usually happens because of the faulty ballast or bulbs. In my case I replaced bulbs which I got from an online store, I would suggest you try these ones or if you had tried something like this before, so replacing ballast would be a better option. Here’s the link of bulbs: https://xenons4u.co.uk/h7-55w-super-white-xenon-effect-headlight-bulbs.html Quote Link to comment Share on other sites More sharing options...
