xpeterpx Posted January 9, 2017 Share Posted January 9, 2017 Just curious but has anyone been able to raise the gearstick slightly just so the gearknob sits a couple inches higher? Mk1 focus by the way if it helps. Thanks Quote Link to comment Share on other sites More sharing options...
Russ Posted January 9, 2017 Share Posted January 9, 2017 You could manufacture an 'extension' quite easily depending on how the gearknob is connected to the shaft. Quote Link to comment Share on other sites More sharing options...
xpeterpx Posted January 9, 2017 Author Share Posted January 9, 2017 The knob is just screwed onto the shaft Quote Link to comment Share on other sites More sharing options...
mac801123 Posted January 9, 2017 Share Posted January 9, 2017 It's not just the shaft you need to extend. The reverse mechanism needs extending as well. The bit you lift to select reverse has 2 arms that go down along side the shaft for the lock selector (so you don't put it in reverse by mistake as your traveling forwards). Quote Link to comment Share on other sites More sharing options...
xpeterpx Posted January 9, 2017 Author Share Posted January 9, 2017 Ok harder than i thought Quote Link to comment Share on other sites More sharing options...
mac801123 Posted January 9, 2017 Share Posted January 9, 2017 Quote Link to comment Share on other sites More sharing options...
mac801123 Posted January 9, 2017 Share Posted January 9, 2017 It just so happens I have one to hand... lol Quote Link to comment Share on other sites More sharing options...
mac801123 Posted January 9, 2017 Share Posted January 9, 2017 Gaiter removed for clarity. 2 Quote Link to comment Share on other sites More sharing options...
Russ Posted January 15, 2017 Share Posted January 15, 2017 Not so hard to do, as you said, the knob screws onto the shaft so what's wrong with adding an 'extension' onto the screwed shaft to only lift the gearknob as per the OP request. I'm assuming you don't lift the gearknob to select reverse. If you do then do as Mac801123 says Quote Link to comment Share on other sites More sharing options...
xpeterpx Posted January 15, 2017 Author Share Posted January 15, 2017 Exactly right just hoping to add a bit of top end extension rather than a full overhaul. Can i please ask for ideas on how to acheive this regards to bits needed etc. Quote Link to comment Share on other sites More sharing options...
Lenny Posted January 15, 2017 Share Posted January 15, 2017 25 minutes ago, xpeterpx said: Exactly right just hoping to add a bit of top end extension rather than a full overhaul. Can i please ask for ideas on how to acheive this regards to bits needed etc. If the outter black sleeve section is metal aswell then you could purchase a second unit from the breakers, use it to extend the existing one by chopping and welding, There's also plenty of gear gaitor manufacturers on eBay that can manufacture an extended gaitor for the focus if you asked them. Quote Link to comment Share on other sites More sharing options...
mac801123 Posted January 15, 2017 Share Posted January 15, 2017 Here to help again as I got the bits on hand... The parts are hard plastic the two rods for the reverse gear section have two holes at 84mm centers. If you extend the main shaft by two inches the the rods will need the same.as long as you extend the parts by the same amount then it will work. You could make the parts out of 1mm thick aluminium. Do not remove or adjust the sleeve screwed on the shaft or the cables to the box will be out of sync. Hope this helps. Quote Link to comment Share on other sites More sharing options...
mac801123 Posted January 15, 2017 Share Posted January 15, 2017 Something else I've just looked at is the bit that's screwed on the shaft has a locator on it so you will need one from a scrapped car to fit after the extension is done. It's to stop the top bit from rotating when you change gear, and also it has a spring between the know and the part you lift. The other possible thing I've thought about is not to extend too much as it will give a longer throw at the top so every time you put it in 1st, 3rd and 5th you may end up punching the stereo. Not a good move if you like you music... Quote Link to comment Share on other sites More sharing options...
