Pillar trim
IRONMAN
 Share
Hi again, Thanks for all the recent help. Would anyone know if the pillar trims can be removed from the 2008 focus for painting. I tried vinyl wrap but it won't stick to the dimpled surface. Cheers
  • Like 2
Link to comment
On a mk25 focus you will first need to remove small rectangular plastic trim that says Airbag on it , which will reveal 2 phillips screws .undo these , pull away door rubber. Now you will need to undo torx sealtbelt bolt on bottom of c- pillar. Then slide belt out of trims slot. Btw if 3 door i have black St225 trims to sell .
Yunii
Sent from my SM-G925F using Tapatalk
  • Like 5
Link to comment
forgot about them:smile:
Two screws behind it,
  • Like 2
Link to comment
The external ones are a pig to remove without snapping any of the 3 lugs that hold it in place, it also has factory applied adhesive to make sure it doesn't go anywhere.  I'd say if you're going to remove them, be prepared to potentially have to replace them.
  • Like 1
Link to comment
15 hours ago, 1979Damian said:
The external ones are a pig to remove without snapping any of the 3 lugs that hold it in place, it also have factory applied adhesive to make sure it doesn't go anyway.  I'd say if you're going to remove them, be prepared to potentially have to replace them.
Cheers Damian, Will probably give it a miss
  • Like 1
Link to comment
18 hours ago, IRONMAN said:
Thanks again guys for all the reply's and great help. It is the external pillar / window trims, I was looking for. So sorry.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
