keefola Posted January 15, 2017 Share Posted January 15, 2017 Hi there, Can one of you please advise me which code reader I could get for my Ford Fiesta Zetec 2003. Too many to choose from on eBay? not sure if allowed to post links to eBay but is this ok?http://www.ebay.co.uk/itm/Car-Fault-Code-Reader-MaxiScan-MS309-Engine-Scanner-Diagnostic-OBD2-EOBD-AUTEL-/131865744160?_trksid=p2141725.m3641.l6368 Many thanks Quote Link to comment Share on other sites More sharing options...
Tuffers69 Posted January 15, 2017 Share Posted January 15, 2017 I bought one like that because I had an abs light on and it wouldn't tell me which sensor it was, as far as I can gather the only thing it's good for is clearing codes! i ended up buying this https://www.ebay.co.uk/itm/132034268924 it plugs into a laptop if you have one, download forscan. It shows you everything in great deal and you can even activate hidden features on your car. It told me it was the rear abs sensors aswell as historic codes when the handheld one couldn't even pick up the current faults. I would highly recommend! *edit* fixed the link Quote Link to comment Share on other sites More sharing options...
keefola Posted January 16, 2017 Author Share Posted January 16, 2017 thanks for your reply Tuffers69. i ended up buying the one i linked! hopefully it'll be ok! i was messing around (trying to fix) with the heater/cold air control as it wasnt working. was just blowing cold. the sensor came on bout 30 mins into driving, with the heater on. hoping its related to the engine light hoping its a cheap fix! Quote Link to comment Share on other sites More sharing options...
