jam251991 Posted January 16, 2017 Share Posted January 16, 2017 I own a MK7 Ford Fiesta 1.6 TDCi Zetec S with 17" alloy wheels (black street pack). One of the alloys is bucked and is no longer maintaining pressure. Exploring whether to buy a replacement and change the 4 x alloys to another Fiesta style/size. Can anyone clarify which other Ford fiesta alloys I could run? Would 15" 4 stud alloys fit? Many thanks in advance. Quote Link to comment Share on other sites More sharing options...
DieselPig Posted January 16, 2017 Share Posted January 16, 2017 Yes. Quote Link to comment Share on other sites More sharing options...
isetta Posted January 16, 2017 Share Posted January 16, 2017 alloys buckle more easily than steel wheels. add to that, the wider the wheel, the weaker it is on the inside edge, and add to that the larger the diameter of wheel, the skinnier the tyre is so there is not so much rubber to buffer the strike on the wheel (and also more chance of scraping rim along kerb as tyre not so high). Large alloys do look good but there is a price to pay for looking good, as described above Quote Link to comment Share on other sites More sharing options...
jam251991 Posted January 17, 2017 Author Share Posted January 17, 2017 Thanks, so the 15" alloys of tyre size 195/50/R15 will fit to replace my 17" 205/40/R17 alloys with no fitment or clearance issues? Quote Link to comment Share on other sites More sharing options...
DieselPig Posted January 17, 2017 Share Posted January 17, 2017 Correct. Quote Link to comment Share on other sites More sharing options...
ThaiFiesta Posted January 17, 2017 Share Posted January 17, 2017 8 hours ago, jam251991 said: Thanks, so the 15" alloys of tyre size 195/50/R15 will fit to replace my 17" 205/40/R17 alloys with no fitment or clearance issues? A lot depends on the offset / ET of the original and replacement wheels. An alloy with markedly different offset may causing rubbing Your speedo is likely to be out also. There are calculators online that will calculate for you how much the difference +/- is. Quote Link to comment Share on other sites More sharing options...
dfriel2 Posted January 17, 2017 Share Posted January 17, 2017 If the 15" wheels are from another fiesta, they will fit and the offset won't be a problem. The change in speedo reading from 205/40/17 to 195/50/15 is about 3%, and it would over read (which is a good thing to avoid speed tickets!) Quote Link to comment Share on other sites More sharing options...
