Sign in to follow this
rm9
Somewhat planned S-Max 2.5T ST sleeper build
Hello everyone,
First off, the reason im posting in this neck of the woods regarding an S-Max is because you lot have the Focus ST/RS 2.5 which has pretty much the same engine, just more toys.
I'm planning to purchase an S-Max in the coming months and mod it past the 300+bhp mark, maybe even 400 if my pockets are deep enough, while making the car look somewhat standard (little touches here and there). To achieve the 300 mark, this is what i have planned:
Celtic tuning remap. Brings power/torque up from 217bhp/239lbft to 278bhp/315lbft
RS clutch upgrade: DMF, pressure plate, clutch, throwout/release bearing
AIRTEC intercooler
Scorpion turbo back decat/200 cell cat exhaust or custom, not decided yet.
Air filter of some sort/ CAIS
inlet plenum maybe?
new LSD
Uprated injectors
block mod
bigger brakes 355mm< discs and 6/8 pot calipers (front)
Forged engine (rods, liners, pistons etc.)
uprated turbo
Turbosmart e-boost 2 boost controller
estimated figure after all mods completed: 340-370bhp and around 400lbft torque
What else would anyone say i need/recommend? Thanks for reading
Richard
Everything you stated above still comes down to what engine you are using.
If you are using the normal 2.5 that is found is some Smax then 300 Bhp may be a issue But to 400 you would need load more work.
One guy had already done this, it's a green smax. Uses a Focus RS engine. But the flames are a flamethrower kit. You may see it on YouTube etc.
I looks like the 2.5 engine in the smax will go up to 270ish with stage 1 remap.
But I'm not 100% sure if you would need the famous block MOD or not. Being kind of the same engine I think you may need that first before pushing more power.
I was just looking up the block mod and i am considering having it done once the mods start racking up. after ive had it done, im considering having an uprated turbo but that wont come for a long while i reckon
Get block MOD done at the same time as the clutch swap. This issue is once the block is cracked it's useless, even if repaired the issue tends to come back.
it's safer to do it. and since engine is apart anyway the couch can be put in also.
Also the block mods renews most parts so the engine will be all set up to take the increased performance.
thats a very good idea. ill think ill do that
I take it it's a BIG block to fit a couch in it? :whip:
  Only 75 emoji are allowed.
