dickeygreen Posted January 21, 2017 Share Posted January 21, 2017 Hi, I have fitted a new exhaust on my 2001 Mondeo Estate today, however when I look into it I couldn't find anything that said it needed paste between the joints... Can anyone advised if the back joints need paste or not? The front part has a gasket! Thanks Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 21, 2017 Share Posted January 21, 2017 I would put a very small amount on the sleeve joints but nothing on the front joint as it should contain a round gasket/ring which crushes. Quote Link to comment Share on other sites More sharing options...
dickeygreen Posted January 21, 2017 Author Share Posted January 21, 2017 balls that means I've got to get some now :) Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 21, 2017 Share Posted January 21, 2017 21 minutes ago, dickeygreen said: balls that means I've got to get some now :) Try it without you might get lucky if you have got good U clamps i fitted a klarius exhaust not long ago on a mk3 estate and had to use paste, wouldn't seal without. Quote Link to comment Share on other sites More sharing options...
dickeygreen Posted January 21, 2017 Author Share Posted January 21, 2017 Yeah might just buy some tomorrow and fit it while its still on the ramps... only cost £2.. I'm guessing I need to remove the U clamps and put it inside! :) Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 21, 2017 Share Posted January 21, 2017 34 minutes ago, dickeygreen said: Yeah might just buy some tomorrow and fit it while its still on the ramps... only cost £2.. I'm guessing I need to remove the U clamps and put it inside! :) Yep, take the exhaust apart and smear a small amount on the smaller diameter part of the sleeve joint and then slide the next section over it and fit the clamp. i tend to cure the paste with a blow torch or heat gun whatever is handy as I find it always seems to wash out otherwise. 1 Quote Link to comment Share on other sites More sharing options...
dickeygreen Posted January 22, 2017 Author Share Posted January 22, 2017 So went to get some fuelgum however they didn't have any.. Even though online said they had 1 gggrrr So bloke in the shop said this is exactly the same. (attached photo) Quote Link to comment Share on other sites More sharing options...
