H4wkeye Posted January 23, 2017 Share Posted January 23, 2017 Hello, I'm planning to clean the throttle body on my 2005 Fiesta 1.25, I'm just wondering what is the relearn procedure? Should I just take the negative off the battery, take the TB out, clean it then fit it back in, put the negative back on and start the car and let it idle for ~10 mins? Or is there some other way? Is it even necessary to do it? Thanks, cheers! Quote Link to comment Share on other sites More sharing options...
iantt Posted January 23, 2017 Share Posted January 23, 2017 Reconnect then ign on for 1min , not starting it. Ign off and wait a while, can't remember how long off hand. Then start up and it will be fine. 2 Quote Link to comment Share on other sites More sharing options...
H4wkeye Posted January 23, 2017 Author Share Posted January 23, 2017 Alright, thanks mate, I'll do it like that. Quote Link to comment Share on other sites More sharing options...
iantt Posted January 24, 2017 Share Posted January 24, 2017 will see if i can have look for exact procedure later if i remember 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted January 24, 2017 Share Posted January 24, 2017 It is ign on and wait 1 minute, ign off. Job done . Don't touch the throttle pedal in that 1 minute. 1 Quote Link to comment Share on other sites More sharing options...
H4wkeye Posted January 24, 2017 Author Share Posted January 24, 2017 Sweet, should be straight forward then. First time cleaning the TB, seems like it's not too hard. Just the hose a bit tricky to reconnect those clips but I got some pliers, should do the trick. Thanks! Quote Link to comment Share on other sites More sharing options...
Focusladmk2 Posted January 19, 2021 Share Posted January 19, 2021 On 1/24/2017 at 11:46 AM, H4wkeye said: Sweet, should be straight forward then. First time cleaning the TB, seems like it's not too hard. Just the hose a bit tricky to reconnect those clips but I got some pliers, should do the trick. Thanks! Hi did this work ? Quote Link to comment Share on other sites More sharing options...
