MOT advisory note (Suspension arm rubber bush deteriorated & constant velocity joint gaiter deteriorated)
M Lam
 Share
Hi
I saw this on my new MOT is an advisory note
  • nearside front constant velocity joint gaiter deteriorated, but preventing the ingress of dirt (2.5.C.1a)
  • nearside front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
  • offside front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Just curious, is this easy to change? And how much it will cost to fix it? Do you think is worth to fix it. And what will be the problem, if I don't fix it?
  • Like 1
Link to comment
It will only get worse if left and yes its worth it to fix on a 2006 ask your
self if you think the cars a good one.
Do you do repairs yourself
  • Like 1
Link to comment
I guess this might not be an easy job for me to do it. I will get someone to do it. Do I need to do it immediately, or I can do it few months later? Any idea how much that will cost?
Link to comment
3 hours ago, M Lam said:
Hi
the mot tester is just making you aware that these parts are worn through normal wear & tear and will need replacing at some point in the future , but are not dangerous or impede use of the car.
so i wouldnt panic to get the repairs done in the next week or anything.
just keep calm and carry on.
  • Like 2
Link to comment
1 hour ago, dezwez said:
cost goes on what parts you use copied or dealer parts :smile:
Just curious, this is the part needed to fix all above issue is below?
http://www.eurocarparts.com/ecp/c/Ford_Focus_2.0_2005/p/car-parts/transmission-parts/car-transmission/cv-joint-kits/?657593821&1&e14a73317f55522dad3bdfc45682384fb59bc136&000095
Link to comment
you dont need the whole cv kit just the rubber bit. - for the first fault.
and 2 rubber suspension bushes for faults 2 & 3. about £20 each.
go to a motor factors for the parts , they will sell you only the stuff you actually need
  • Like 1
Link to comment
Thanks. This help :)
Link to comment
some mot testers put loads of stuff on advisories and some don't. It does not neccessarily mean those parts are worse on your car than on one where it was not mentioned at all. there is no consistency.
I would not have the work done now if it was mine , but i would keep an eye on the gaiter now and then because if it splits and dirt and water gets in then it can ruin the joint itself. but some have minor cracks in the rubber gaiter that can last for years. Gaiters vary in quality. the original part might last years, but a cheap replacement might be poor quality rubber that splits in much less time. I have found the same with steering rack gaiters. there is a fair bit of work in fitting CV gaiters so you don't want it to fail again too soon
some decisions depend on how long you think you might keep the car.
Link to comment
I would try cleaning the brushes with silicone spray first. I mean it won't hurt to double check it.
I mean I had a dealer health check that said detoriating break lines and a broken rear spring, it was broken but broken so low it did not matter, I also noticed how bad the break line looked. I just wiped off the dirt and the brake line looked brand new.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
