Pullock Posted January 27, 2017 Share Posted January 27, 2017 So we got our car at the start of December, however last weekend I had the Engine service now message with the Yellow spanner light followed by start/stop not available. My bluetooth elm327 code reader couldn't find anything, So I've bought a modified USB adapter for use with FORScan, these are the codes it has pulled. I've had a look both on here and on google and can't seem to find these codes related to the same problem so hopefully some of you can shed some light on it, I've had no trouble since but don't want to just let it lie in case it could lead to anything more sinister. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
madmole Posted January 27, 2017 Share Posted January 27, 2017 Basically saying a front parking sensor is duff. the other code has stored but is not current Wipe the codes and see if they come back Quote Link to comment Share on other sites More sharing options...
Pullock Posted January 27, 2017 Author Share Posted January 27, 2017 7 minutes ago, madmole said: Basically saying a front parking sensor is duff. the other code has stored but is not current Wipe the codes and see if they come back I don't even have front parking sensors, that could be the issue lol. Wasn't sure if it could of been referring to active city stop. Quote Link to comment Share on other sites More sharing options...
madmole Posted January 27, 2017 Share Posted January 27, 2017 Is you have active stop then there is a radar unit in the front behind one of the triangular panels. its saying that isn't working. Check the connections for water and clean contacts Quote Link to comment Share on other sites More sharing options...
Pullock Posted January 27, 2017 Author Share Posted January 27, 2017 10 minutes ago, madmole said: Is you have active stop then there is a radar unit in the front behind one of the triangular panels. its saying that isn't working. Check the connections for water and clean contacts Hmm I think we have it but I'm unsure, it doesn't say I have it on ETIS but it says I don't have Sat Nav either. (Which I do) Quote Link to comment Share on other sites More sharing options...
madmole Posted January 27, 2017 Share Posted January 27, 2017 Load up Focccus software and download car config to see what the car thinks it has. then check its actually there Quote Link to comment Share on other sites More sharing options...
Pullock Posted January 27, 2017 Author Share Posted January 27, 2017 7 minutes ago, madmole said: Load up Focccus software and download car config to see what the car thinks it has. then check its actually there Thanks, I'll give it a try. Quote Link to comment Share on other sites More sharing options...
Pullock Posted January 28, 2017 Author Share Posted January 28, 2017 15 hours ago, madmole said: Load up Focccus software and download car config to see what the car thinks it has. then check its actually there I loaded Focccus and attempted to read the BPC and got the following error message "could not get ccc address from ecu" I've had a lookon google but can't see this error anywhere. Quote Link to comment Share on other sites More sharing options...
