Aftermarket Stereo help required
i3lade4life
 Share
I am trying to install a Sony DAB radio in my Focus 52 plate. I have used a wire harness found online and it powers up once the ignition is on. But when I use the radio the volume is set to a stupidly high level and then I cannot scan for stations on FM. I have tried switching the red/yellow cables together but still nothing changes.
Any advice is much appreciated
Link to comment
Have you got a DAB aerial for your car?
Also check out this wiring harness just in case the one you have isn't right just compare not suggesting buy it, just check to see if yours looks the same or similar. https://www.connects2.co.uk/Product/ProductItem/CT20FD01
Another option is an auto electrician but they can be expensive but I'm pretty sure someone at Halfords will know exactly what to do and they charge from £30
Edited by Ryan_Tango
Spelling mistake
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
