Dondolino Posted February 2, 2017 Share Posted February 2, 2017 Hi need help!!! ford focus 2013 ( mk3) screen washers jet not squirting water all 3 jets stopped squirting at the same time all of the sudden. the pump is defiantly trying to pump water out I can ear the noise, I have disconnect the tube under the bonnet to check if front jets are blocked but no water is coming out, also I have syphoned the scrennwash bowl few times with clean water few bits of crap come out but jets still not delivering water!!!! Any help will be much appreciated. 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted February 2, 2017 Share Posted February 2, 2017 if you take out the water tank from the car its normally under one of the wheel arches you will see a pump motor pull this out and you will see a rubber filter that's what's blocked just clean it and it should be fine Quote Link to comment Share on other sites More sharing options...
Dondolino Posted February 2, 2017 Author Share Posted February 2, 2017 Thank very much dezwez I will try this weekend. Quote Link to comment Share on other sites More sharing options...
Dondolino Posted February 7, 2017 Author Share Posted February 7, 2017 hi dezwez I did have a go and bear in mind I'm not very good with cars a manage to clear the rubber filter and now is back up and working fine thanks for your help. 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted February 7, 2017 Share Posted February 7, 2017 your welcome Quote Link to comment Share on other sites More sharing options...
