Albert27 Posted February 23, 2017 Share Posted February 23, 2017 Afternoon all. In the strong winds today a piece of metal has come loose and was hanging down near exhaust at rear. Probs already loose but the wind seriously dislodged it further so I pulled it out. There was nothing holding it in. Pictures to follow.. My questions. What is it? Is it important? How do I replace/fix it? Thanks in advance. 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted February 23, 2017 Share Posted February 23, 2017 its part of the heat shield you can put it back on with over size washers and nuts not hard to do 2 Quote Link to comment Share on other sites More sharing options...
Albert27 Posted February 23, 2017 Author Share Posted February 23, 2017 2 minutes ago, dezwez said: its part of the heat shield you can put it back on with over size washers and nuts not hard to do What's it protecting from heat? If the bolts i saw up in the space are for it - and looking at the size of the holes, maybe it's just rusted away. In that case, would i need a new one? If not, Can you give me a a link to the type of washers/nuts you mean? Cheers mate! 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted February 23, 2017 Share Posted February 23, 2017 it protects the rear floor from the heat of the exhaust no need to renew it just put bigger washer than the holes in it http://www.ebay.co.uk/itm/A2-Stainless-Steel-Penny-Repair-Mudguard-Big-Washers-ALL-SIZES-IN-STOCK-/332058482169?var=541091113396&hash=item4d503a55f9:m:m54P3EUQiGTEUPWr6_4CZ1wand re fix it 2 Quote Link to comment Share on other sites More sharing options...
dezwez Posted February 23, 2017 Share Posted February 23, 2017 you will probley be Able to see the nut type fitting that hold it on as heat shield holes get bigger and it fall off the car just turn them to remove them Quote Link to comment Share on other sites More sharing options...
Albert27 Posted February 23, 2017 Author Share Posted February 23, 2017 24 minutes ago, dezwez said: it protects the rear floor from the heat of the exhaust no need to renew it just put bigger washer than the holes in it http://www.ebay.co.uk/itm/A2-Stainless-Steel-Penny-Repair-Mudguard-Big-Washers-ALL-SIZES-IN-STOCK-/332058482169?var=541091113396&hash=item4d503a55f9:m:m54P3EUQiGTEUPWr6_4CZ1wand re fix it Thanks for that Dez. Finally is it ok to drive with it off for a week or so while i wait for the washers? If not i could try and wedge it up there temporarily......... 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted February 23, 2017 Share Posted February 23, 2017 it protects the rear floor from the heat of the exhaust no need to renew it just put bigger washer than the holes in it http://www.ebay.co.uk/itm/A2-Stainless-Steel-Penny-Repair-Mudguard-Big-Washers-ALL-SIZES-IN-STOCK-/332058482169?var=541091113396&hash=item4d503a55f9:m:m54P3EUQiGTEUPWr6_4CZ1wand re fix it its will fine to drive without it some members actually take it off and leave it off I put mine back on as its part of the car 2 Quote Link to comment Share on other sites More sharing options...
isetta Posted February 23, 2017 Share Posted February 23, 2017 similar heatshield fell off on my wife's mazda2, same thing happened, it corroded away where the bolts washers were holding it on, hence the big holes. as said above it can be refitted using bigger washers (washers which are bigger then the holes in it). i did not bother refitting it on the mazda2. it seemed just to stop the heat getting to the boot floor. i suppose in theory the heat might shorten the life of the spare tyre by a microscopic percentage or make your frozen food shopping defrost. old cars did not have these. it might be worth checking you don't have any pipes / hoses for brakes / petrol very close by. 1 Quote Link to comment Share on other sites More sharing options...
Jonanstee Posted February 24, 2017 Share Posted February 24, 2017 I've had all my heat shilds off for a good 6 months or so now. No problems at all so you will be fine leaving it off :) 1 Quote Link to comment Share on other sites More sharing options...
madmole Posted February 24, 2017 Share Posted February 24, 2017 It must actually do something or Ford wouldn't go through the cost of making one and fitting it to every car 1 Quote Link to comment Share on other sites More sharing options...
Albert27 Posted February 24, 2017 Author Share Posted February 24, 2017 5 minutes ago, madmole said: It must actually do something or Ford wouldn't go through the cost of making one and fitting it to every car I agree with the logic so although it's off temporarily, I've bought the washers and am going for the fix next week. As always, thanks for all the advice people! 1 Quote Link to comment Share on other sites More sharing options...
ScaniaPBman Posted February 25, 2017 Share Posted February 25, 2017 14 hours ago, madmole said: It must actually do something or Ford wouldn't go through the cost of making one and fitting it to every car I recon this heat shield is needed but only in extreme conditions that this spec of model might see. This could be a long steep hill climb at close to full throttle in 35 to 40 C ambients, then a stop at the top. You will have a really hot exhaust system right to the tailpipe radiating and convecting considerable heat affecting nearby components. Since you and I are unlikely to do this in the near future I would not rush to refit it. ScaniaPBman. Quote Link to comment Share on other sites More sharing options...
stef123 Posted February 25, 2017 Share Posted February 25, 2017 Do a regen on a car with a dpf and no heat shields and let us know how long it takes the carpets to start smoking lol 3 Quote Link to comment Share on other sites More sharing options...
Commencal24 Posted March 5, 2017 Share Posted March 5, 2017 I had to go under my mk2 yesterday and noticed a very loose heatsheild, and a corroded exhaust bracket to go with it 😩 I did start to notice a little knock coming from underneath on acceleration Friday... Quote Link to comment Share on other sites More sharing options...
andypsp Posted March 5, 2017 Share Posted March 5, 2017 1 minute ago, Commencal24 said: I had to go under my mk2 yesterday and noticed a very loose heatsheild, and a corroded exhaust bracket to go with it 😩 I did start to notice a little knock coming from underneath on acceleration Friday... both can be easily fixed so nothing to worry about, the knocking was the heat shield 2 Quote Link to comment Share on other sites More sharing options...
Commencal24 Posted March 5, 2017 Share Posted March 5, 2017 3 hours ago, andypsp said: both can be easily fixed so nothing to worry about, the knocking was the heat shield Had all the bits to sort the issues today but the torrential rain all day put an end to that. Quote Link to comment Share on other sites More sharing options...
andypsp Posted March 5, 2017 Share Posted March 5, 2017 2 minutes ago, Commencal24 said: Had all the bits to sort the issues today but the torrential rain all day put an end to that. weather should be better this week so it will be all systems go for you then matt Quote Link to comment Share on other sites More sharing options...
Commencal24 Posted March 5, 2017 Share Posted March 5, 2017 Hope so, I had loads planned for today, made my template for the additional boot light, purchased led side lights to fit and I couldn't do any of it 😕 Quote Link to comment Share on other sites More sharing options...
Albert27 Posted March 18, 2017 Author Share Posted March 18, 2017 Update: Managed to get two of the jumbo washers on the car but the third heat shield bolt is rounded off. Have put some plus gas on it and will try the hammer and mole grips trick this afternoon. What size are they and where would i get a replacement one? It's like a nut and washer all in one.......... Quote Link to comment Share on other sites More sharing options...
Commencal24 Posted March 18, 2017 Share Posted March 18, 2017 52 minutes ago, Albert27 said: Update: Managed to get two of the jumbo washers on the car but the third heat shield bolt is rounded off. Have put some plus gas on it and will try the hammer and mole grips trick this afternoon. What size are they and where would i get a replacement one? It's like a nut and washer all in one.......... The third bolt on mine was completely corroded, used mole grips to get it off, was a nightmare to find a replacement bolt Quote Link to comment Share on other sites More sharing options...
Albert27 Posted March 18, 2017 Author Share Posted March 18, 2017 6 minutes ago, Commencal24 said: The third bolt on mine was completely corroded, used mole grips to get it off, was a nightmare to find a replacement bolt Couldn't get it off so what I've done as a temporary fix is to screw a nut over the thread that was left and over the rounded off nut. The jumbo washer moves a little but I think it will be enough to hold it in place! So heat shield is back in. Did you use standard mole grips? I've seen these and just wondered if they are superior for rounded nuts and be worth investing in....... https://www.amazon.co.uk/d/Spanners-Wrenches/Toolzone-18-STILSONS-PIPE-WRENCH/B001O5M1ZC Quote Link to comment Share on other sites More sharing options...
Russ Posted March 18, 2017 Share Posted March 18, 2017 On 24/02/2017 at 6:34 PM, madmole said: It must actually do something or Ford wouldn't go through the cost of making one and fitting it to every car All manufacturers use them, not just Ford! It's caused because the 'shield' is aluminium and the nuts are pressed steel so being under the car, road salt, chemical reaction (yadda yadda) causes them to corrode. Some people just cut washers out of an aluminium Coke can and buy new nuts to refit them but as others have already stated they can be safely removed and left off! Take the car to a garage and chances are they'll just rip the part off and ditch it like my local garage did on my fiesta mk6 when I had this happen. Quote Link to comment Share on other sites More sharing options...
Commencal24 Posted March 19, 2017 Share Posted March 19, 2017 On 18/03/2017 at 2:48 PM, Albert27 said: Couldn't get it off so what I've done as a temporary fix is to screw a nut over the thread that was left and over the rounded off nut. The jumbo washer moves a little but I think it will be enough to hold it in place! So heat shield is back in. Did you use standard mole grips? I've seen these and just wondered if they are superior for rounded nuts and be worth investing in....... https://www.amazon.co.uk/d/Spanners-Wrenches/Toolzone-18-STILSONS-PIPE-WRENCH/B001O5M1ZC Yeah I used standard mole grips as only had half a nut to grip on to. So long as your heatsheild doesn't rattle about I think you'll be all good 👍🏼 1 Quote Link to comment Share on other sites More sharing options...
WallaceZS Posted March 20, 2017 Share Posted March 20, 2017 The same heat shield has been hanging down underneath my ZS for a year now, I've just not got around to fixing it. It was an advisory on the MOT, I'll let the garage fix it when it goes in for its service in a couple of weeks. I have seen some people just cut up a Coke can, layer it and use that as an oversized washer. Quote Link to comment Share on other sites More sharing options...
stef123 Posted March 20, 2017 Share Posted March 20, 2017 An oversize washer of tigerseal is what I use depending on the situation. 1 Quote Link to comment Share on other sites More sharing options...
