Ourlee Posted March 10, 2017 Share Posted March 10, 2017 When I activate my front washer jets, wipers come on but rear jets fire instead of front, but when activate rear jets , they work fine. Any clues, I am guessing a blockage of some kind in pipework, any ideas for a quick fix Quote Link to comment Share on other sites More sharing options...
Russ Posted March 10, 2017 Share Posted March 10, 2017 Just an idea...... Sounds stupid but you could try disconnecting the pipe from the front jet (block the other pipe going to the 2nd front jet) and blow down the pipe (either by mouth or you could try a tyre inflator) It may dislodge anything down by the pump, failing that you'd need to get down to the pump/bottle & check for blockages. Quote Link to comment Share on other sites More sharing options...
