Windscreen washers
Ourlee
When I activate my front washer jets, wipers come on but rear jets fire instead of front, but when activate rear jets , they work fine. Any clues, I am guessing a blockage of some kind in pipework, any ideas for a quick fix
Just an idea......
Sounds stupid but you could try disconnecting the pipe from the front jet (block the other pipe going to the 2nd front jet) and blow down the pipe (either by mouth or you could try a tyre inflator) It may dislodge anything down by the pump, failing that you'd need to get down to the pump/bottle & check for blockages.
