Sign in to follow this
jimjamyaha
It's an oil leak! Help for fix
Hey,
Car has been drinking oil for past 6 months or so. Checked it wasn't burning it.
Finally got round for the UV dye test... After a 20min drive can clearly see where the leak is coming from (see attached pics). A bit of a relief as thought it was coming from much higher from the top of the engine or PVC pipes or oil filter, but that must be black road gunk all above.
Is this a oil pan gasket leak? How fixable are these on a MK2 Petrol... A pain?
difficult to say. it could be the oil seal at the end of the cranskshaft behind the flywheel (unless I am misunderstanding what I see in the picture)
Hey, if it helps from this pic the bolthead side is on the oil pan side, the side where the drip is coming from is on the next section.1489262817882.thumb.jpg.35d27d8ae7491121
Out of interest does this section get removed when a clutch is replaced?
  Only 75 emoji are allowed.
