Harleysdad Posted March 11, 2017 Share Posted March 11, 2017 I have a 2009 1.8 Duratec he focus and have recently had a new 3 piece clutch fitted. Ever since this, when driving in 1st the car will sometimes make a sound almost like metal rubbing on metal. For a few seconds before stopping (sounds like an angle grinder lol) . This isn't accompanied with any clutch slip or loss Of Power and isn't at any particular speed just in 1st gear Quote Link to comment Share on other sites More sharing options...
Harleysdad Posted March 11, 2017 Author Share Posted March 11, 2017 Or is am I completely wrong and this is the normal abs self test noise... Will test tomorrow Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted March 12, 2017 Share Posted March 12, 2017 ABS test kicks off at around 15mph which can sound like the engine has fallen off its mount when turning full lock at the same time. it will only do I once per engine off on cycle so if you come to a stop and try again without turning engine off it wont do it Quote Link to comment Share on other sites More sharing options...
Harleysdad Posted March 12, 2017 Author Share Posted March 12, 2017 Yep. Exactly that. Took the car out today. Usually makes the noise as I hit a speedbump on my street, and I get a sort of clunk or sometimes a metal grinding noise for a split second at around 15mph and however much I try to recreate it.... It happens once per journey..... Pain in the back side but at least I know it's not my gearbox falling off lol.. Thanks guys Quote Link to comment Share on other sites More sharing options...
Micro Posted March 13, 2017 Share Posted March 13, 2017 3 hours ago, Harleysdad said: Yep. Exactly that. Took the car out today. Usually makes the noise as I hit a speedbump on my street, and I get a sort of clunk or sometimes a metal grinding noise for a split second at around 15mph and however much I try to recreate it.... It happens once per journey..... Pain in the back side but at least I know it's not my gearbox falling off lol.. Thanks guys Mine does the grinding noise if you're turning the wheel any significant amount whilst it happens - if you're driving straight it will just clunk. Quote Link to comment Share on other sites More sharing options...
Harleysdad Posted March 15, 2017 Author Share Posted March 15, 2017 Mine sounds to me like a metal grinding metal for a split second. Always at 12mph and only once per journey. Case closed Quote Link to comment Share on other sites More sharing options...
