Focus MK1 Rear Seat removal - Nuts are a pain
Dagger
 Share
I'm having a nightmare trying to get these seats out - 2 bolts are remaining that I cannot get to turn whatsoever
I've tried penetration spray - worked on the others but not these
I'm starting to round the nuts now :ohmy:
HELP
Link to comment
HELP
Hi Daz, never tried taking seats out but have you tried using mole grips?  Plusgas is pretty good if you ain't already used it.
Link to comment
You can't get to grip anything as it doesn't protrude like a normal bolt, it's almost flush with the floor
I've managed to get one out eventually, but the other one is now rounded inside
Link to comment
I have just had the rear seats out of my MK2.5 Focus. I guess your MK1.5 is much the same.
You don't say which bolts are actually causing a problem. Some have the end of the threaded part exposed under the car and I recon it is one of those that is stuck.
What I would do is to be radical. Just drill the offending bolt right out, You can estimate the drill size from one of the other bolts.
Then replace this with a bolt and nut. Forget about trying to put a thread back into the body hole.
Job done.
ScaniaPBman.
Link to comment
Job done.
ScaniaPBman.
They are TORX Bolts - so the so the part where you unscrew is in the middle
Link to comment
Finally sorted it :biggrin:
Borrowed a TORX key and had to hammer it in to get a good grip
I'm not  removing seats again :sad: what a pain they've been
Thanks everyone
  • Like 1
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
