adw85 Posted April 9, 2017 Share Posted April 9, 2017 Hi I have a MK2.5 Zetec S with a CD6000 headunit with bluetooth hands free and Voice control and im trying to add a USB socket to it I have heard that you can plug a usb lead into the bluetooth module to get a USB socket for a memory stick? I have tried turning on BT/VC High + USB + BT audio using elmconfig but it always wants to revert back to BT/VC Low is the module that i have not compatable or is it somthing else? I look forward to a reply Anthony Quote Link to comment Share on other sites More sharing options...
Jezza54 Posted April 9, 2017 Share Posted April 9, 2017 You need the Ford music Box Ford part number 1746768 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted April 9, 2017 Share Posted April 9, 2017 To retrofit the original Ford Sound & Connect system (Bluetooth/Voicecontrol with bluetooth Audio, USB and Ipod support) you need to change the Bluetooth/Voicecontrol module for a Sound & Connect module (this type of module is different from the standard Bluetooth/Voicecontrol module). Next to the module you also need the correct type of cable and socket. The Sound & Connect system is only supported by the original Sony radio's and the Travelpilot FX and NX sat nav radio's. The 6000CD does not support the additional Sound & Connect functionality. If you want to retrofit the Sound & Connect system you also have to change the radio. Quote Link to comment Share on other sites More sharing options...
