D13 HPD 95 Posted April 20, 2017 Share Posted April 20, 2017 Anyone fitted the puma speed boost solenoid valve? http://www.pumaspeed.co.uk/product-Pumaspeed-Focus-Heavy-Duty-Boost-Solenoid_15739.jsp i had it turn up today but no fitting instructions and they don't supply them apparently.... Quote Link to comment Share on other sites More sharing options...
dezwez Posted April 20, 2017 Share Posted April 20, 2017 there some sort of instructions at the bottom of the page you put up Which way around do the pipes go ? The valve has each port numbered 1 ,2 and 3 Port 1 = Return line ( this goes back into the turbo intake which faces upwards on the start of the Turbo intake) Port 3 = Presure feed ( this goes to the line that exits normally from the side of the Turbo intake) Port 2 = Actuator Feed (this line goes directly to the actuator.) Please be aware that the unit will not work correctly any other way around and could result in serious overboost problems and subsequenet engine damage if not proprly fitted .If you are in any doubt whatsoever please print this page and take the Pumaspeed uprated solenoid valve to a professional workshop for installation. Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted April 20, 2017 Author Share Posted April 20, 2017 Dez, i did see that but im more after where is this soleniod valve and which line is which Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted April 21, 2017 Author Share Posted April 21, 2017 Has anyone done this mod can help a lad out :) Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted April 24, 2017 Author Share Posted April 24, 2017 If anyone is interested in this mod the valve is located just on the turbo, its a wheel off wheel arch out and you should be able to get to it Quote Link to comment Share on other sites More sharing options...
