Stouty Posted June 25, 2008 Share Posted June 25, 2008 I have a problem when I open the door the BUZZ noise don't go on to tell me I have the headlights on!!!! And also the top MAP light don't work! It should be on when the door is closed and off when the door opens? (or is it the other way round) I checked the fuses and they seem OK could any one help thanks. FORD FIESTA ENCORE 1997 1.3 5Door Is that an MK4??? Quote Link to comment Share on other sites More sharing options...
Stouty Posted June 27, 2008 Author Share Posted June 27, 2008 I have a problem when I open the door the BUZZ noise don't go on to tell me I have the headlights on!!!! And also the top MAP light don't work! It should be on when the door is closed and off when the door opens? (or is it the other way round) I checked the fuses and they seem OK could any one help thanks.FORD FIESTA ENCORE 1997 1.3 5Door Is that an MK4??? I have got the buzzing working now I cleaned the switch that gos in and out as the door shuts but still the Map light don't work on courtesy any ideas Quote Link to comment Share on other sites More sharing options...
kevin lancelott Posted February 26, 2009 Share Posted February 26, 2009 Maybe it could be a bulb problem.you can replace them. Quote Link to comment Share on other sites More sharing options...
poohbear Posted February 27, 2009 Share Posted February 27, 2009 I have a problem when I open the door the BUZZ noise don't go on to tell me I have the headlights on!!!! FORD FIESTA ENCORE 1997 1.3 5Door Is that an MK4??? I know you said you've solved the problem but this used to happen quite a bit on my 2001 fiesta. The little switch in the door kept getting lost in the rubber of the door and in the end ford had to fit a new one. Didnt really bother me as most people told me i had left my lights on!! Quote Link to comment Share on other sites More sharing options...
