Craigh0911 Posted April 27, 2017 Share Posted April 27, 2017 Does any1 think this anti-roll bar needs replaced? I'm not sure if the bushings broke. I have noticed my car swaying/rocking left and right when driving and think this may be it. I've also included a photo of the track rod end because i've heard that that may be the reason for the swaying/rocking. Any help would be appreciated. Thanks 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted April 27, 2017 Share Posted April 27, 2017 There cheap enough to replace the drop links I think they have seen better days 1 Quote Link to comment Share on other sites More sharing options...
Craigh0911 Posted April 27, 2017 Author Share Posted April 27, 2017 Thanks Dez Are droplinks also called anti roll bars? Yeah the anti roll bars/droplinks haven't been changed in a while. Could that be what's causing the swaying/rocking? 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted April 27, 2017 Share Posted April 27, 2017 They are the links between anti roll bar and suspension legs so called drop links, Wont hurt to change them to see if it stop the swaying and rocking 1 Quote Link to comment Share on other sites More sharing options...
Craigh0911 Posted April 27, 2017 Author Share Posted April 27, 2017 Cheers. On euro car parts these look like what i need? 1 Quote Link to comment Share on other sites More sharing options...
Craigh0911 Posted April 27, 2017 Author Share Posted April 27, 2017 Do the track rod ends look ok? 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted April 27, 2017 Share Posted April 27, 2017 they look fine just grab each one and see if you can move it back and fourth if it only moves a bit its fine 2 Quote Link to comment Share on other sites More sharing options...
dezwez Posted April 27, 2017 Share Posted April 27, 2017 6 minutes ago, Craigh0911 said: Cheers. On euro car parts these look like what i need? if you put your reg in then they are the ones 2 Quote Link to comment Share on other sites More sharing options...
Craigh0911 Posted April 27, 2017 Author Share Posted April 27, 2017 Thanks mate. Really appreciate it 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted April 27, 2017 Share Posted April 27, 2017 your welcome 1 Quote Link to comment Share on other sites More sharing options...
Craigh0911 Posted April 27, 2017 Author Share Posted April 27, 2017 Checked the track rod ends there and theyr fine. Very little to no movement. They got the replace on the last MOT (Oct 2016) so didn't think they'd need replaced but thought I'd check since the bearing looks a bit squashed. 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted April 27, 2017 Share Posted April 27, 2017 there not bearing there rubber covers Quote Link to comment Share on other sites More sharing options...
Craigh0911 Posted April 27, 2017 Author Share Posted April 27, 2017 Bushings I meant sorry. No big deal then? 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted April 27, 2017 Share Posted April 27, 2017 no 1 Quote Link to comment Share on other sites More sharing options...
Craigh0911 Posted April 27, 2017 Author Share Posted April 27, 2017 Cheers again 👍 1 Quote Link to comment Share on other sites More sharing options...
Micro Posted April 27, 2017 Share Posted April 27, 2017 £20 for one anti roll bar link is a bit steep to me (but I'm a cheapskate!) Unipart have them for £8ish each, delivery is about £5ish iirc. I changed mine as a matter of course when I did my suspension arm - I think the new ones are aluminium vs the steel of the original ones. 1 Quote Link to comment Share on other sites More sharing options...
Russ Posted April 27, 2017 Share Posted April 27, 2017 Is it me or does the bolt look sheared in the last photo? Quote Link to comment Share on other sites More sharing options...
Micro Posted April 27, 2017 Share Posted April 27, 2017 16 minutes ago, Russ said: Is it me or does the bolt look sheared in the last photo? It does, but I think it's just blended in. From taking mine off (one side at a time), the ARB tends to spring away if they're undone. 1 Quote Link to comment Share on other sites More sharing options...
Craigh0911 Posted April 28, 2017 Author Share Posted April 28, 2017 10 hours ago, Micro said: £20 for one anti roll bar link is a bit steep to me (but I'm a cheapskate!) Unipart have them for £8ish each, delivery is about £5ish iirc. I changed mine as a matter of course when I did my suspension arm - I think the new ones are aluminium vs the steel of the original ones. Had a look on unipart (as a fellow cheapskate) but theyre out of stock. Hadnt heard of that site before though - so thanks for that. Quote Link to comment Share on other sites More sharing options...
Craigh0911 Posted April 28, 2017 Author Share Posted April 28, 2017 10 hours ago, Russ said: Is it me or does the bolt look sheared in the last photo? See, i thought that myself but think it might just be the lighting. The bar is sturdy enough but it definitely looks like its due for a replacement. 1 Quote Link to comment Share on other sites More sharing options...
jmurray01 Posted April 29, 2017 Share Posted April 29, 2017 I don't think the anti-roll bars would have an effect on the car in normal driving, but only on fast cornering/bumps when the suspension would be pushed to the extremes of its travel. I am open to correction if I am wrong though! Quote Link to comment Share on other sites More sharing options...
Craigh0911 Posted May 1, 2017 Author Share Posted May 1, 2017 UPDATE: Changed my anti roll bar drop links yesterday and seems to have done the trick. Car feels more stable (going around corners, driving on the motorway, normal driving etc). The droplinks id taken off have never been replaced, they were that rusted on that i ended up having to take them off with an angle grinder. Thanks for every1s advise. Craig 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted May 1, 2017 Share Posted May 1, 2017 glad to hear it 1 Quote Link to comment Share on other sites More sharing options...
