paulliver Posted December 25, 2009 Share Posted December 25, 2009 the wifes heater matrix is blocked so im thinking of changing it anybody done the above and how did you do it cheers paul Quote Link to comment Share on other sites More sharing options...
InstructorPiggy Posted December 25, 2009 Share Posted December 25, 2009 Hey, not a difficult job, just time consuming and fiddliy! It requires removal of the dashboard...remoaval of part of heater system, block off matrix pipes, then remove matrix. Replace, partly refit heater system and sit dash in place, then top up coolant system, run engine and bleed system and ensure matrix not leaking! Run engine ensuring no air locks and matrix gets warm, then you can fit dash back fully :) Expect spending a good day! :) Quote Link to comment Share on other sites More sharing options...
stevej2209 Posted December 29, 2009 Share Posted December 29, 2009 the wifes heater matrix is blocked so im thinking of changing it anybody done the above and how did you do itcheers paul You don't need to remove the dash at all, it takes about an hour to do. Look under the bonnet to the back and centre of the vehicle, you'll see two pipes leading through a soft covering. Follow the pipes and you should see them attached to a removable plate held in by 4 screws, that's where the heater matrix sits. Any more help just give me a message. Quote Link to comment Share on other sites More sharing options...
paulliver Posted December 29, 2009 Author Share Posted December 29, 2009 You don't need to remove the dash at all, it takes about an hour to do. Look under the bonnet to the back and centre of the vehicle, you'll see two pipes leading through a soft covering. Follow the pipes and you should see them attached to a removable plate held in by 4 screws, that's where the heater matrix sits. Any more help just give me a message. hi steve sent u a message thanks paul Quote Link to comment Share on other sites More sharing options...
paulliver Posted January 3, 2010 Author Share Posted January 3, 2010 You don't need to remove the dash at all, it takes about an hour to do. Look under the bonnet to the back and centre of the vehicle, you'll see two pipes leading through a soft covering. Follow the pipes and you should see them attached to a removable plate held in by 4 screws, that's where the heater matrix sits. Any more help just give me a message. did what u said m8 didnt take long,i flushed a load of rust /crap out of the matrix refitted it and hey presto???now have hot air blowing :) im thinking of dropping all of the coolant out when it get a bit warmer then refilling it all with fresh .i will flush the radiator and heater matrix out first then add fresh anti-freeze and water should be fine thanks for the help paul Quote Link to comment Share on other sites More sharing options...
