StevenG89 Posted May 1, 2017 Share Posted May 1, 2017 So on Sunday I tried to start my beauty she ticked over but won't start checked the battery and has plenty charge and won't jump start suggestions? Thanks Quote Link to comment Share on other sites More sharing options...
muttmich Posted May 2, 2017 Share Posted May 2, 2017 Possible starter motor, is it making any noise whatsoever or is it just tick tick ticking, the starter motors on these little ferraris are at the front of the engine slightly behind the radiator so get covered in road crud really easily. Quote Link to comment Share on other sites More sharing options...
StevenG89 Posted May 3, 2017 Author Share Posted May 3, 2017 Yeah the engine is trying to start should have mentioned she's a mk6 rs2000 Also any info on where the fuel cut off switch is? Quote Link to comment Share on other sites More sharing options...
muttmich Posted May 15, 2017 Share Posted May 15, 2017 Im sure the cut off switch is in passenger foot well but don't quote me on that, did you get it sorted? Quote Link to comment Share on other sites More sharing options...
Frembrit Posted July 3, 2017 Share Posted July 3, 2017 My brother had a K reg RS2000 and that used to have trouble starting now and again. A procedure that we tried was to unplug the wire from the injectors, and start the engine. It would then cut out as there wasn't any fuel. Reconnect plugs and start it again. Not a permanent solution but it might get you going. Ultimately the problem was fue box related, which is a common problem. I actually changed it on the RS, my other brothers Orion Ghia SI, and two of my friends XR3i's. From memory they get moisture inside and it corrodes the internals, which usually affects the electrical supply for the fuel system (i think), and a bodge was to take a feed from another fuse loaction and plug it in to the fuel fuse location. I can't remember which fuse though. This is the actual wire I used. Quote Link to comment Share on other sites More sharing options...
Gizza11 Posted July 3, 2017 Share Posted July 3, 2017 On 03/05/2017 at 1:04 PM, StevenG89 said: she's a mk6 rs2000 my boyhood dream I always wanted one of these never got one nice car Quote Link to comment Share on other sites More sharing options...
StevenG89 Posted July 4, 2017 Author Share Posted July 4, 2017 Thanks guys sorry for the late reply but she's all good now Quote Link to comment Share on other sites More sharing options...
