Immobiliser Active
frenchspanner
Mondeo 2012
On 4/5/2021 at 7:37 AM, waynes had enough with it said:
Mondeo 2012
I’m getting this reading on pins 6-14 obd
with engine bay plugs disconnected
mans blue plug on PCM
If I check pin 3-11 on obd with everything plugged in I get 60oms and if I just unplug the engine plug I get 120oms7AA4BFD5-7B12-499E-93B4-0EF520B9E13E.thumb.jpeg.a5e85a7fff2c9104ebdb66b9a9a41e82.jpeg
Does anyone have a wiring diagram on what pins to test on what plugs
According to the diagram I am looking at the HS CAN connector routing is;
CJB (BCM) => DLC => C23-CD => C12-AB => PCM (ECU)
Connector C23-CD is shown around passenger side of centre console, should be a 12 pin connector. Bus pins are 5 & 6, they should be a twisted pair, White & White/Blue.
Connector C12-AB is in the left hand A pillar. Looks like a 40 pin multiplug
See if you can find the C23-CD connector. Reseat it and check for 60ohms there.
The other connector could be tough to get to.C23-CD.thumb.jpg.b9d66498b999eb88ec9f2f4b79b7c322.jpg
Thanks I will try and look tomorrow
I can’t see plug c12-ab in the drawing
c23 I think I’ve  found white plug in picture at the bottom left
am I checking ohms  with the plugs connected or disconnected or one plug to the other
Great you found the twisted White & White/Blue wires.
The connector you have doesn't match the diagram I have but at least you've found the routing.
Unplug the connector and check for 120 ohms on both plug and socket, I think the side that has the female pins goes back towards the DLC and the male pins go towards the PCM.
The C12 connector is shown on a different diagram, the wiring is likely to be in the A pillar somewhere but I can't say where for sure now as I'm not looking at the correct wiring diagram. You'll just have to look for the  twisted White & White/Blue wires.
The only other diagrams I can find are for much later models with the DLC integrated into the Gateway Module and not terminating at the CJB BCM.
JIC it helps;
JIC it helps;
Ok so I’ve checked ohms reading the same on these plugs one plug was connected wile the other one was tested
the black plug runs off through the bulkhead to engine
and the white plug runs up and around the dash inside the car
Hi Wanye, I can see from the photo you checked the female half, did you also test the male pins on the other half ?
Yes no reading on the other sides of plug
Hi Wayne, the side of the connector with no reading is the side with the fault. The male pins should be going to the PCM (Dan62 can you please confirm this for Wayne). There is a 120 ohm resistor inside the PCM so you should have had 120 ohm on each half of the connector.
You need to do a continuity test between the wires on the half of C23 that is open circuit and the connector of the PCM, I expect you will find a break in one of the wires, or even both but that would most likely indicate that there is another connector between C23 and the PCM.
Test the wires and let us know what you find.
Dan62 will be able to confirm if there are more connectors in the harness.
31 minutes ago, unofix said:
Hi Wayne, the side of the connector with no reading is the side with the fault. The male pins should be going to the PCM (Dan62 can you please confirm this for Wayne). There is a 120 ohm resistor inside the PCM so you should half had 120 ohm on each have of the connector.
Ok cheers will let you know what I find
3 hours ago, Dan62 said:
How are you getting on?
Hi sorry for the late reply just finished a 12 hr night shift
I’ve tested the plus the white to blue plug at the board and resistance it good on both wires at 6 ohms, with the blue plug plugged into the board I get the 122 ohms on female side
on the male side nothing open circuit that side of the plug runs off up the dash to ?
Hello Wayne, I'm not sure we are understanding each other, this is getting a bit indepth but lets crack on and get this fixed.
The half of the connector with the pins that are open circuit should be the end of the harness thats from the PCM. Have you managed to locate the PCM unit ?
You need to do a continuity check from the plug of the PCM back to the connector with the male pins. Sorry if this is already what you have done but I'm not sure that I'm correctly understanding what you have tested so far.
If you check from the plug of the PCM back to the other connector and all is well, then the next step is to check the pins on the PCM itself, and you should get 120 ohms.
So I’m guessing the pcm is the fuse board in the passenger foot well and that’s what the blue multi plug goes to
ive  unplug that and tested the wiring from there to the white plug as in picture
wiring seems ok however the other side of the white plug that connected to that has open circuit where does it go to as it runs up through the dash
i will check the two pins on the board in the morning to see if I get a reading or open circuit
Hi Wayne now I understand where we are going wrong. The Fuse board  is the BCM - Body Control Module.
You need the PCM - Power Control Module or as it may be called the ECU
You have proved the BCM is ok, but now you need the PCM.
Dan62 might be able to help you locate it.
It’s ok I know where that is passenger wing
I will do some test on that side
and let you know
and let you know
Ok done some checks to ecu and abs can link , blue and white from large black plug in foot well and on on wire ok but is getting High resistance on the pin next to it
is there anything else on the circuit
I think I have 2 wires touching each other somewhere
2 hours ago, Dan62 said:
Sorry, I don't understand what you have written.
See attached diagram, it might help.
Ok
the black plug in the first picture has can link wires white, white/blue and they run through the bulkhead into the engine bay
ive tested the wires white to white to the  pcm and abs and both read ok on resistance but if I cross over from one end only say I am on the plain white wire on the black plug and check the white pin terminal at pcm is ok, but if I move across to the blue/white pin abs end only that’s when I get high resistance so I’m going from white at one end and over to b/W the other end
so that would be normal or are there wires touching each over
From what you have checked I would say the white/blue wire is broken between the black connector and the engine compartment.
As previously mentioned there should be another connector inside the vehicle, A pillar / bulkhead area which is where you need to look next.
Ok cheers will take a look Saturday some time
so would the male side off that plug run back to the obd plug or does it go through the BCM first
Just gone through the posts again.
Looks like the black plug with wires going through the bulkhead is the one I thought we were still searching for :confused1:.
Leave the Black plug disconnected and now working under the bonnet check the CAN BUS resistance at the ABS connector, it should be 120 ohms with the PCM connector plugged in.
Forget about the BCM and obd end, you have verified that is ok.
If the above test is 120 ohms the break is between the black plug and the ABS connector. If its high resistance or open circuit the break is in the engine bay.
