ff2007 Posted May 14, 2017 Share Posted May 14, 2017 Hi everyone, Any good fix out there for those broken air hose clips? Ff. Quote Link to comment Share on other sites More sharing options...
dezwez Posted May 14, 2017 Share Posted May 14, 2017 wire tie Quote Link to comment Share on other sites More sharing options...
ff2007 Posted May 14, 2017 Author Share Posted May 14, 2017 Have it with zip ties but it doesn't hold tight. 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted May 14, 2017 Share Posted May 14, 2017 jubilee clip 1 Quote Link to comment Share on other sites More sharing options...
Albert27 Posted May 14, 2017 Share Posted May 14, 2017 Re secured mine with jubilee clips. Been snug ever since. Quote Link to comment Share on other sites More sharing options...
ff2007 Posted May 14, 2017 Author Share Posted May 14, 2017 1 hour ago, Albert27 said: Re secured mine with jubilee clips. Been snug ever since. Have any pic? Quote Link to comment Share on other sites More sharing options...
Albert27 Posted May 15, 2017 Share Posted May 15, 2017 8 hours ago, ff2007 said: Have any pic? I'll get one later for you after work and post it. They were all standard clips bought in a pack from Halfords and then i got one big one (100mm if i remember right) separately for where it joins the air filter housing. I'm assuming you mean the air breather hose thing? Quote Link to comment Share on other sites More sharing options...
Albert27 Posted May 15, 2017 Share Posted May 15, 2017 Jubilee clips and one clip tie for good measure...... Quote Link to comment Share on other sites More sharing options...
ff2007 Posted May 15, 2017 Author Share Posted May 15, 2017 Nice! But you have clips in place as far as I see. I want to make a fix for thos broken clips. Cheers and thanks for the pic! 👍 Quote Link to comment Share on other sites More sharing options...
south_bound Posted May 15, 2017 Share Posted May 15, 2017 The clips are broken on mine as well and I use a couple of cable ties to hold it on, wrapped around whatever I can like the rigid pipe and yellow plastic thing in the top picture above. Just have to put on new ones every time I do an air or oil filter change. Quote Link to comment Share on other sites More sharing options...
ff2007 Posted May 15, 2017 Author Share Posted May 15, 2017 7 minutes ago, south_bound said: The clips are broken on mine as well and I use a couple of cable ties to hold it on, wrapped around whatever I can like the rigid pipe and yellow plastic thing in the top picture above. Just have to put on new ones every time I do an air or oil filter change. Pic? Quote Link to comment Share on other sites More sharing options...
simcor Posted May 15, 2017 Share Posted May 15, 2017 Buy a new hose off eBay, cheaper than the Ford part and will have working clips, they are easily damaged though. Think I paid around 30 quid for the replacement air intake hose with the breather hose attached. Sent from my HTC One M9 using Tapatalk Quote Link to comment Share on other sites More sharing options...
simcor Posted May 15, 2017 Share Posted May 15, 2017 Look at this on eBay http://www.ebay.co.uk/itm/252917043994Even cheaper although I may have paid less than 30 quid for mine, just seemed to ring a bell.Sent from my HTC One M9 using Tapatalk Quote Link to comment Share on other sites More sharing options...
