salsheikh Posted May 18, 2017 Share Posted May 18, 2017 hi guys, the wife's purchased a Fiesta MK7 and when i was washing her car i noticed the mirrors were loose. I opened the door and took the grommet off the reveal the torq screw and thought I'd tighten it but it was already very tight so couldnt so was hoping someone on here knows of a fix? Also, the mirror caps appear to come off very easily and they are a pain in the derrier to put back on. Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted May 18, 2017 Share Posted May 18, 2017 The mirror caps are usually a bit of a nightmare to take off And the plastic trim can occasionally feel loose but it should clamp down a bit once the nuts tightened Which part is loose? Quote Link to comment Share on other sites More sharing options...
salsheikh Posted May 18, 2017 Author Share Posted May 18, 2017 Hi Kieran the base part is loose. i can rock the mirror with ease! Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted May 18, 2017 Share Posted May 18, 2017 When your removed the grommet, did you check the little pins that locate it are in place? Failing that, take the nut off, whack a washer on the inside of it and tighten again, see if it takes up the slack Possibly had the mirrors replaced with non genuine ones Quote Link to comment Share on other sites More sharing options...
salsheikh Posted May 18, 2017 Author Share Posted May 18, 2017 1 minute ago, GingerFlame said: When your removed the grommet, did you check the little pins that locate it are in place? Failing that, take the nut off, whack a washer on the inside of it and tighten again, see if it takes up the slack Possibly had the mirrors replaced with non genuine ones now i did not know there are locating pins. i shall have a look at this. with regards to the washer - do i need to take the mirror/door trim etc off to get access? i do hope they are oem mirrors.... Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted May 18, 2017 Share Posted May 18, 2017 I mean leave the mirror on, and just remove the nut, whack a washer on. And stick the nut back on again There should be one or two locating pins I forget :) 1 Quote Link to comment Share on other sites More sharing options...
salsheikh Posted May 18, 2017 Author Share Posted May 18, 2017 got ya will do this tonight...no i wont. i'm off to watch baywatch tonight so will do this over the weekend or when she's nice to me!!! 1 Quote Link to comment Share on other sites More sharing options...
