handymr Posted December 31, 2009 Share Posted December 31, 2009 Hi all I have a mk1 04 42000 miles focus, since the cold weather over xmas time I've noticed a creaking noise from the suspension, seems worse when driving slow and turning right but you can still hear it whilst driving in a straight line.it seems to come from the drivers side. I had no problems upto the very cold weather kicking in which included driving in the snow and ice . The car does not pull either way and the brakes work fine. Can road salt causes the bushes to dry out and if so is there anything that can be applied to stop the noise. any help or suggestions would be appreceiated. cheers andy ...... Quote Link to comment Share on other sites More sharing options...
InstructorPiggy Posted January 1, 2010 Share Posted January 1, 2010 yeah probably the inner antiroll bar bushes....cheap and easy to replace, but try some spray lube in there...they do dry out easy and perish :) Quote Link to comment Share on other sites More sharing options...
handymr Posted January 2, 2010 Author Share Posted January 2, 2010 yeah probably the inner antiroll bar bushes....cheap and easy to replace, but try some spray lube in there...they do dry out easy and perish :) Quote Link to comment Share on other sites More sharing options...
handymr Posted January 2, 2010 Author Share Posted January 2, 2010 I had a look today , took the drivers wheel off and I think the problem is the drop link between the strut and anti roll bar , every time I raised the the strut with a trolly jack the drop link moved and made the clanging noise. do these need replacing in pairs because the other side is okay .... many thanks for ur reply ...... andy ....... <_< Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 2, 2010 Share Posted January 2, 2010 I had a look today , took the drivers wheel off and I think the problem is the drop link between the strut and anti roll bar , every time I raised the the strut with a trolly jack the drop link moved and made the clanging noise. do these need replacing in pairs because the other side is okay .... many thanks for ur reply ...... andy ....... <_< i would say yes replace in pairs, if one side is away then the other side probably wont be too far behind. i think they come in pairs to buy anyway. Quote Link to comment Share on other sites More sharing options...
InstructorPiggy Posted January 2, 2010 Share Posted January 2, 2010 no, they come in singles. Often the N/S goes more often because it gets more abuse (holes tend to be on left of road etc) I didnt realise it was a clang/bang....thought you said creak! defo change it, just the one side be fine...easy enough :) Quote Link to comment Share on other sites More sharing options...
handymr Posted January 2, 2010 Author Share Posted January 2, 2010 mine look to have a bolt on each end , is it just a matter of loosening them off and they will pop out (that sounds too easy) any instructions or pics would be appreceiated ..... andy ....... Quote Link to comment Share on other sites More sharing options...
InstructorPiggy Posted January 2, 2010 Share Posted January 2, 2010 mine look to have a bolt on each end , is it just a matter of loosening them off and they will pop out (that sounds too easy) any instructions or pics would be appreceiated ..... andy ....... yep :) they have a nut on the end of a bolt...but sometimes in turning the nut you turn the bolt. SO first clean off the threads and getting some freeing oil in there. Then look at the end of the bolt, sometimes there is a place to put an allen key. SO you can use a spanner to loosen the nut whilst holding the bolt with the allen key. If not...on the link is a rubber bush, you need to get some vicegrips on that bush as inside is the other end of the bolt, so you then can hold the bolt tight whilst removing the nut :) 20minutes, job done :) Piggy :) Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 2, 2010 Share Posted January 2, 2010 ahwell, learn something new every day. never done them on a ford but on my last car they came as a pair. nice one piggy. Quote Link to comment Share on other sites More sharing options...
handymr Posted January 2, 2010 Author Share Posted January 2, 2010 Thanks for that info, I'll see if i can pick one up from the local motor factors tomorrow and get it replaced , I'm glad it only takes 20 mins its started snowing again here in yorkshire so don't want to freeze my nuts off !!! once again many thanks andy ....... :P Quote Link to comment Share on other sites More sharing options...
handymr Posted January 3, 2010 Author Share Posted January 3, 2010 got the part today cost me £10.60p for drivers side FAI product, Just one final question does it matter which nut to undo 1st top or bottom? Hoping to get it done tomorrow (weather permitting) so i'll report back tomorrow guys ..... Quote Link to comment Share on other sites More sharing options...
handymr Posted January 5, 2010 Author Share Posted January 5, 2010 FIXED see new post took 1 hour including a cuppa to warm me up. anybody with knocking noise look at these 1st they are the weakest link in the suspension setup, also cheap and easy to replace. I sust these were the problem by putting the car on axle stands and then removing the wheel and putting a trolly jack under hub/brake disc and raising it and lowered it. it knocked and you could feel the vibration on it as you raised it up and down. All help and suggestions appreceiated many thanks andy ........... Quote Link to comment Share on other sites More sharing options...
