Patrico777 Posted June 11, 2017 Share Posted June 11, 2017 This morning on way to work I think my slave cylinder is gonne same as clutch not sure if it is gearbox as well oil came out and the clutch pedal is loose dead what I include pictures how muchI am looking at for fix ? Car is on 76k Quote Link to comment Share on other sites More sharing options...
Jethro_Tull Posted June 11, 2017 Share Posted June 11, 2017 Concentric slave cylinder? Seems likely, but no way of knowing without dropping the box. Quote Link to comment Share on other sites More sharing options...
Patrico777 Posted June 11, 2017 Author Share Posted June 11, 2017 32 minutes ago, Jethro_Tull said: Concentric slave cylinder? Seems likely, but no way of knowing without dropping the box. Yeah hopefully its clutch ! Im not sure its gearbox oil that came out or brake fluid my brake fluid reservoir is half of it Quote Link to comment Share on other sites More sharing options...
Jethro_Tull Posted June 11, 2017 Share Posted June 11, 2017 Aye, the reservoir is divided in such a way that a clutch leak won't cause a brake failure. Quote Link to comment Share on other sites More sharing options...
Patrico777 Posted June 12, 2017 Author Share Posted June 12, 2017 8 hours ago, Jethro_Tull said: Aye, the reservoir is divided in such a way that a clutch leak won't cause a brake failure. Ahhh so its all good then I am getting towed to garage today so brakes will work that is good I was worried 1 Quote Link to comment Share on other sites More sharing options...
Patrico777 Posted June 12, 2017 Author Share Posted June 12, 2017 Car is in garage got towed and on dashboard popped msg saying low brake fluid level check owners guide so I guess it was brake fluid That leaked I ordered new clutch from euro car parts £250 LUK brand 1 Quote Link to comment Share on other sites More sharing options...
Patrico777 Posted June 13, 2017 Author Share Posted June 13, 2017 Its gearbox as well it has hole inside !!! Quote Link to comment Share on other sites More sharing options...
Jethro_Tull Posted June 13, 2017 Share Posted June 13, 2017 Holy Corbyn! What's happened to it? Quote Link to comment Share on other sites More sharing options...
GaryPL Posted June 14, 2017 Share Posted June 14, 2017 You been racing around, Patrico777? Quote Link to comment Share on other sites More sharing options...
Patrico777 Posted June 15, 2017 Author Share Posted June 15, 2017 There is hole in box its self from bottom not sure what happend Quote Link to comment Share on other sites More sharing options...
Patrico777 Posted June 15, 2017 Author Share Posted June 15, 2017 On 14. 6. 2017 at 1:25 AM, GaryPL said: You been racing around, Patrico777? No driving normally not saying like granny did push it a bit but that what is made for the car Quote Link to comment Share on other sites More sharing options...
Jethro_Tull Posted June 15, 2017 Share Posted June 15, 2017 I feel your pain Bro. New box? Quote Link to comment Share on other sites More sharing options...
stef123 Posted June 15, 2017 Share Posted June 15, 2017 Looking at the pics there is no way that is brake fluid, far too much of it and also wrong colour. an expensive day out for you. 1 Quote Link to comment Share on other sites More sharing options...
Patrico777 Posted June 15, 2017 Author Share Posted June 15, 2017 Oh yeah it cost me £700 in total box new clutch labour 1 Quote Link to comment Share on other sites More sharing options...
Patrico777 Posted June 15, 2017 Author Share Posted June 15, 2017 Just this here wheb twisted is bit noisy seller said will be fine once installed on car Quote Link to comment Share on other sites More sharing options...
stef123 Posted June 15, 2017 Share Posted June 15, 2017 the input shaft is twisted? no danger would i even attempt to fit that. Quote Link to comment Share on other sites More sharing options...
Patrico777 Posted June 15, 2017 Author Share Posted June 15, 2017 No when mechanic have twisted this highlighted there on pic it made little noise seller said once fitted wil be fine Quote Link to comment Share on other sites More sharing options...
stef123 Posted June 15, 2017 Share Posted June 15, 2017 ah you mean when rotated? it is a little noisy. Sorry it read to me that the input shaft was twisted lol Quote Link to comment Share on other sites More sharing options...
Patrico777 Posted June 15, 2017 Author Share Posted June 15, 2017 11 minutes ago, stef123 said: ah you mean when rotated? it is a little noisy. Sorry it read to me that the input shaft was twisted lol Yeah when rotated sorry I am so fed up that I dont even no what I am saying hahaha makes little noise when rotated Quote Link to comment Share on other sites More sharing options...
Jethro_Tull Posted June 15, 2017 Share Posted June 15, 2017 It'll make a little, particularly if the box has been dry for a while, but if the shaft rotates smoothly and feels smooth you should hopefully be fine. Quote Link to comment Share on other sites More sharing options...
Patrico777 Posted June 15, 2017 Author Share Posted June 15, 2017 3 hours ago, Jethro_Tull said: It'll make a little, particularly if the box has been dry for a while, but if the shaft rotates smoothly and feels smooth you should hopefully be fine. Yeah turns nice and smoothly no problem at all getting it fitted latest on Sunday 1 Quote Link to comment Share on other sites More sharing options...
Patrico777 Posted June 17, 2017 Author Share Posted June 17, 2017 On 15. 6. 2017 at 7:18 PM, Jethro_Tull said: It'll make a little, particularly if the box has been dry for a while, but if the shaft rotates smoothly and feels smooth you should hopefully be fine. Just got the job done the gear knob feels so stiff, clutch is nice and smooth what could be the problem? there is picture of old gearbox broken and also new one installed Quote Link to comment Share on other sites More sharing options...
Jethro_Tull Posted June 17, 2017 Share Posted June 17, 2017 Clutch bled out properly? Clutch properly aligned on the flywheel? None of the gear cables snagged or trapped? Quote Link to comment Share on other sites More sharing options...
Patrico777 Posted June 17, 2017 Author Share Posted June 17, 2017 2 minutes ago, Jethro_Tull said: Clutch bled out properly? Clutch properly aligned on the flywheel? None of the gear cables snagged or trapped? I hope so I will call that guy ask him as it just does not seem right Quote Link to comment Share on other sites More sharing options...
Patrico777 Posted June 17, 2017 Author Share Posted June 17, 2017 47 minutes ago, Jethro_Tull said: Clutch bled out properly? Clutch properly aligned on the flywheel? None of the gear cables snagged or trapped? We can check that but all I've done is remove and refit he said Quote Link to comment Share on other sites More sharing options...
