Jhg23 Posted June 29, 2017 Share Posted June 29, 2017 Hi guys, Looking for some help with a problem I have. I recently put a donor engine into my 1.6tdci after the original decided to throw a con rod through the block (lucky right at the end of a 6 hour trip from cornwall) anyway got an engine, stripped everything off the old and fitted to new, put it in, blead fuel etc. And popped battery on. It starts with the turn of the key but cuts out after 5 - 10 seconds. Shows no codes when scanned and I have searched forums to find an answer with no sucess. It did once throw up 2 codes for the maf but after a good clean they disappeared. Any ideas? Thanks. Quote Link to comment Share on other sites More sharing options...
madmole Posted June 29, 2017 Share Posted June 29, 2017 Fuel pump not able to keep up while running? Quote Link to comment Share on other sites More sharing options...
isetta Posted June 29, 2017 Share Posted June 29, 2017 so when it cuts out, will it start again immediately when you turn the key, or do you have to leave it a while, or does it need a lot of turning on the starter motor before it fires again? fuel is my first fault eg. is the filter your old one, or the old one on the engine you bought or a new one? or still some air in the fuel pipes? 1 Quote Link to comment Share on other sites More sharing options...
