fusionfan2 Posted January 22, 2016 Share Posted January 22, 2016 Thanks for the picture guide, my connections seem ok, but maybe the nearside one was a tiny bit loose. Have re-connected and will see in the morning if cold enough if it has made any difference. Quote Link to comment Share on other sites More sharing options...
fusionfan2 Posted January 24, 2016 Share Posted January 24, 2016 Here are today's findings - drivers side connector was a bit loose, and there is also a small tear? Is this the cause of the fail? can't tell today as not cold enough. And why is damp getting in the car - hang on if you remove the rain drain from the end of the scuttle - the screen rubber has a gap - is this causing a problem? Should it be like that? Quote Link to comment Share on other sites More sharing options...
