P0299 turbo underboost
Cara4890
 Share
Can anyone help me?
currently im having issue with a p0299 fault  code. Turbo was replaced last year, as well as fuel filter. So we probably could rule out clogged filter and failing turbo. I've checked all intercooler hoses.
The intercooler has oily black deposits on the lower left corner and there is also black sooty deposits directly around the union coming out of the intercooler towards the intake. I've tightened the clamp and tested and seems that there is no leaks (only tested with idle revving)
the turbo seems to be working ok, while the car is stationary I can rev the engine slowly and I can hear the turbo spool up only to cut out around 2000 rpm. Although while driving I can hear whizzing noises when accelerating and shifting gears.
I have used an obdII Scanner and the MAP sensors reads around 100 kpa at idle is this normal?
Has any one got any ideas?
Ford S-max 2008
2.0l diesel
Link to comment
Split pipe where the oil is or was on the pipe you adjusted try taking that off chances are you have a split in pipe. When your driving car and the turbo kicks in it will make a whooshing noise if there a pipe loose or split
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
